As per title, anyone running these wheels tubeless, do I need the kit (comes with rubber rim strip with valve) or just the yellow tape, valves and sealant?
Wanting to run Schwalbe Pro One tyres, anyone got this set-up successfully?
I'm running that exact setup. Tape (you can use gorilla tape etc, ) valves and sealant is all you need. I couldn't get them to seat just with a track pump but just used co2 canister for each wheel. I run mine be at about 60psi. I would say swap all the alloy nipples now.. As mine seized up after winter..
Thanks will be giving it a go tonight
Cloudnine - are they v3 or v4 CX discs?
Thanks,
A
V3.. Didn't really think about the nipples when I bought them.. Wasn't until I broke a spoke and the wheel was out that I realised..
Cool. What size Pro Ones are you running? 25/28/30?
A
Stans tape and sealant works fine too, seated first time
