Kielder 100 Singles...
[Closed] Kielder 100 Singlespeed ratio
[#4209469]
Just wondering if anyone with previous Kielder 100 experience can give a bit of singlespeed ratio advice?
I normally ride singlespeed in the lakes on 29er with a 32:20 ratio and find it is a good compromise for the climbs & rougher stuff but a bit spinny on smoother stuff. For the kielder I was looking at gearing up slightly to either a 32:19 or even 32:18 as last year I remember there being a lot of faster sections (was on gears last time).
What singlespeed ratios have you used previousy and if you rode it again would you use the same ratio again.
Posted : 30/07/2012 12:21 pm
Anyone?
Posted : 30/07/2012 3:14 pm
32:16 on normal sized wheels was dry when I did it fancy a ride tonight?
Posted : 30/07/2012 4:02 pm
if only there was a way of taking more than one ratio around with you.
Posted : 30/07/2012 4:03 pm
tracknicko - Member
I suppose it could be done if you were too weak to cope with just the one gear.... 😆
Posted : 30/07/2012 4:26 pm
postierich - Member
Riding from my house at 7pm if you fancy it?
Posted : 30/07/2012 4:31 pm
