Just had my frame p...
[Closed] Just had my frame powder coated and............
[#1666549]
my seat post is super tight due to powder inside. Who do I remove it so I don't scratch my seat post.
Can I get it faced, just like you can do with your headset??
Help!!
Posted : 02/06/2010 3:31 pm
Yep, but you'll have to find a shop with a seat tube reaming tool in the right size, which may not be all that easy.
Posted : 02/06/2010 3:32 pm
Should be able to get the worst of it out carefully with a knife or a file, I'd have thought....
Posted : 02/06/2010 3:34 pm
left over grit blasting media, scratched all my seatpost up, give it really good clean out..
Posted : 02/06/2010 3:35 pm
 juan
emery clothes glued to a tube.
And some jet washing before putting the BB in.
Posted : 02/06/2010 3:39 pm
 Tim
old sacrificial seatpost as a reamer 🙂
or an undersized one with a bit of sand paper on it
Posted : 02/06/2010 3:53 pm
the frame is a 853 steel, 27.2mm, but like it ieda of a smaller post with sandpaper on!
Posted : 02/06/2010 3:55 pm
Dremel?
Posted : 02/06/2010 3:56 pm
Careful application of a bit of paint stripper, powder generally comes off a treat.
Posted : 02/06/2010 3:58 pm
I think sandpaper on a broom shank should sort it.
Cheers all!
Posted : 02/06/2010 4:06 pm
I used a long straight allen key that came with bombers, duck-taped a bit of kitchen sponge and some fine sandpaper (that green stuff?) in a spiral (if that makes sense? so they're both taped to the metal shaft) then put the other end in a drill.
Then took it off again and reversed it to match the direction of the drill.
Worked pretty well (after I got the amount of sponge right to get the right pressure on the paper). I couldn't and can't think of anything better for the job. I'm not an engineer though!
Posted : 02/06/2010 4:12 pm
is it just me who would get the powder coaters to sort/pay for sorting it?
or is that not the done thing in such situations?
Posted : 02/06/2010 4:19 pm
no just reverse the direction of the drill? most have just such a feature nowadays.
Posted : 02/06/2010 4:26 pm
 Del
depends who did it and how much you paid.
35 quid from a generic powder coater i'd do it myself.
100 quid from argos or similar and you might start asking questions.
this one didn't! my grandpa's old drill.
Posted : 02/06/2010 4:28 pm
Paint stripper (carefully). You want it back to the bare metal without taking any metal away.
Posted : 02/06/2010 4:32 pm
Depends on the amount of paint too, are we talking a bit of overspray, or have they totally coated the inside of your seat tube all the way down?
Posted : 02/06/2010 4:35 pm
