I've just ordered a pair of SLX disc brakes from Ribble but they aren't supplied with rotors. Ideally, I'd like Shimano but I'd consider any brand really as long as they have a braking surface the same width as SLX rotors.
I think they're designed to work with 160mm rotors which is fine for the rear of my bike as the carbon stays are curved so I have clearance issues - I could go to 180mm max. As for the front, I'd be happy to run either a 180mm or 203mm rotor. (adaptors will be required, obviously)
If someone who has SLX SM-RT64 rotors on their bike could measure the braking surface, that would be really helpful too...
Thanks in advance...
yeah ive got slx with XT rotors. all ok as long as you pick the correct adapter
Those floating rotors sure are pretty. ๐
the new shimano floaters are nice too....
I use AShima rotors and have never had any problem with them. Merlin do them
I think the shimano floaters might be centre-lock so no good for me.
I have the Shimano floating rotors (on 2 bikes with SLX and XT) and they are available in 6 bolt as well as centrelock. CRC and Merlin stock them.
They look good and are noticeably stiffer than standard ones. Can't say i notice any difference in performance (running 203/180) but they stay truer for longer so less of the annoying 'chinging' noises....
