offered to bleed a set of these for a mate, got the kit to do it BUT the numpty tried to change the pads himself by TAKING THE CALIPER APART I retightened the lose bolts and bled the brake but fluid is leaking,from the caliper, anyone know if the caliper halves are sealed with anything when assembled?
My juicy threes did this when I had to replace the piston seals. There was a small rubber grommit where the two calipers met. This was part of the piston kit as well, however even when repalced my calipers still leaked.
In the end I repalced the brakes as I just could not fix this!
Good lord, some more evidence for the darwin awards!
He didn't kill himself did he?
There is an 'O' ring between the two caliper halves aorund the fluid transfer port.
even with a fresh 'O' ring mine was not happy and still leaky...
