Juicy 3 resevoir le...
[Closed] Juicy 3 resevoir leak
Evening,
I have just had a looksie over my bike as it has been left alone over winter (singlespeed is for winter Very Happy )Only thing I have done is the pikey trick of turning the lever upside down and keeping it held shut to get some firmness back. Now when I pull the rear brake some brake fluid seeps out of the crack where the resevoir cap is. Could I have killed the seal in the resevoir???? I am starting to think that I should get rid of these brakes.
Posted : 08/05/2009 5:55 pm
one of my 7s was doing that, it was a little overfilled.
Posted : 08/05/2009 6:25 pm
Cheers ๐Ÿ™‚ Wonder if a bleed would sort it??
Posted : 08/05/2009 6:37 pm
 beej
Fluid absorbs moisture over time, expands, leaks. I've had a couple of sets of juicys do it, and a friends set. Seals have been fine. A bleed to replace the old fluid sorts it out.
You can ride with a bit of seepage, and probably not die.
Well, brake seepage that is.
Posted : 08/05/2009 6:49 pm
i literaly took the cap off to take a look at the seal, saw it was very full but as a tiny bit of fluid had naturally came out just replaced the cap and seemed fine.
Posted : 08/05/2009 7:11 pm
Thanks for the help guys ๐Ÿ™‚ Will get them bled. The front brake is way spongey so could do with bleeding anyway.
Posted : 08/05/2009 8:15 pm
