IS to Post adapter ...
[Closed] IS to Post adapter help please.
[#2269908]
Trying to find an adapter to fit my IS front brake callipers to a post mount fork for a 160mm disc. Cannot find one on the Shimano website, CRC have one listed but no picture and out of stock but otherwise they seem to be rarer than hens teeth. I made the mistake of getting a post mount to IS 160mm which is different as it seems they refer to the brake fittings first 🙁 Any help appreciated.
Tom
Posted : 09/12/2010 10:51 pm
is your brake post or is?
Posted : 09/12/2010 10:57 pm
I could be wrong, but I think you need to use a 180mm rotor instead (at least thats the impression I get from looking at the Hope website) it's something i'll need to do soon.
Posted : 09/12/2010 10:59 pm
You may find that you can only run a 180mm rotor with your forks hence the reason you can't find a 160/160 adapter. You'll probably have to get a 180mm rotor.
Yeah it is confusing - they all refer to the fittings in the opposite order to what you would think.
Posted : 09/12/2010 11:01 pm
Hope dose do a mount for post fork to is caliper but i dose add 20mm to your origonal IS disc size. cant remember the part code. im sure we have one so will let you know the part no if i can find it.
Posted : 09/12/2010 11:05 pm
try over [url= http://www.xcracer.com/shop/viewproduct.php?productid=103 ]here[/url]
Posted : 09/12/2010 11:07 pm
Thanks guys, I do realise I could go up a disc size but I dont know if the type I use (Magura Marta wavy one) goes up to 180! Was hoping to stay at 160mm if I can but may have to change - or get an M966 Calliper which is post mount.
Tom
Posted : 09/12/2010 11:10 pm
Mackem or anyone else. I'm just reverting back to IS mount so I have the Hope adapter for Mono Mini and the 180 disc.
Posted : 09/12/2010 11:32 pm
Aye, tis a conundrum indeed specially when you realise the front caliper you av tis an IS mount suitable for a 180mm disc already... doh!
Posted : 10/12/2010 1:35 am
Okay, I may have got this wrong (whisky addled tonight) but is this what you're looking for?
http://www.cyclestore.co.uk/productDetails.asp?productID=11716
This what I used to fit my Giant mph IS calipers to post Rebas. Hard to stop the brake squeal with this set up though.
Or this is an alternative:
http://www.wiggle.co.uk/a2z-adapter-is-to-pm-to-keep-160mm/
Posted : 10/12/2010 2:44 am
I had a similar problem when I first went to PM forks and got some helpful advice here.
http://www.singletrackworld.com/forum/topic/is-caliper-to-post-fork-adapter-advice-please
Posted : 10/12/2010 3:28 am
Cheers all, looks like Tomwood has found one, thanks.
Tom
Posted : 10/12/2010 9:08 am
Kunstler, the Wiggle link looks promising however the questions and answers on it had me confused again!
Midlandtrailquestsgraham, the link was for a 180mm disc which seems much easier but thanks, some good stuff in there.
Tom
Posted : 10/12/2010 9:27 am
