Is this the correct...
[Closed] Is this the correct shifter?
[#5789967]
I need a new front derailleur shifter, to accommodate 2 x 10.
I think I'm going mad - is this the right one for the front end?
http://www.chainreactioncycles.com/shimano-xt-m780-10-speed-trigger-shifter/rp-prod69488
The "left hand" shifter is all it says in the description, am I correct in assuming thats the Front shifter then?
Posted : 21/12/2013 11:12 am
yes, that's correct one
was going to say it's the right one, but that could be confusing!
Posted : 21/12/2013 11:28 am
From the 'questions' on CRC
"Is it compatible with 2 speed front derailleur?
Yes; the M780 shifters have a Mode Selector so you can switch them between 2 or 3 speed operation as required."
and from another "The left hand shifter is suitable for 3 speed and the right hand for 10 speed."
So would imply the left is fine, even though the description talks about 10 cogs etc.
Anyway - just to check, your derailleur is Shimano?
Posted : 21/12/2013 11:41 am
Ah cheers for the clarification - deadkenny yes everthing is shimano and I'm just going from triple to double at the front, and need to replace my existing M770 shifter.
Posted : 21/12/2013 12:59 pm
You don't need a new shifter just adjust the limit screw correctly and you'll be fine.
Posted : 21/12/2013 4:45 pm
Yeah that's what I did before dumping my front derailleur completely!
Posted : 21/12/2013 4:46 pm
