picked up a trek superfly 9.8 with a 100mm head tube. looking at forks with 160mm steerer tube...
A Ragley Stubbing stem has about the lowest stack height at 30mm. That leaves about 27mm for a headset. If it's fully/partially integrated then you might make it.
Can be... you can get a 35mm stack stem, with the headset upper that should be say 40mm... giving you 20mm.
Personally I'd want more just in case... but could be done i think.
Cheers yes as I thought, it is touch and go
Isnt it an integrated headset?
Buy my fox 32s with a long 195mn steerer, then you won't have any worries!😃
the superfly should be integrated headset. You'll have enough steerer at 160 to fit a stem, but not a lot of adjustment.
i've found some rebas with a 190mm steerer, so i think i'll play it safe. Ta!ย good budget integrated headset anyone?
