Does anyone know of one? Maybe one which can be adapted?
I dont really want to spend £200+ on the proper lense
Just send them to these guys and get them to glaze them. It won't be close to £200.
www.reglaze-glasses-direct.com
Google says this.
Inserts are the best. Get a nice collection of lenses in different colours and only need to change one prescription. I don't have the Oakley by the way.
Those are selling on ebay but the price is a bit ott for a piece of plastic.... wow!!!
The oakleys cannot be glazed 🙁
I ran a set of M Frames with an optical insert for a while.
I found it a load of crap. Heavy enough to feel, spaced out the main lens from your face and makes it & the frame really noticeable.Lets loads of dust/wind past but not enough to clear the almost constant fogging that occurred between the 2 lenses.
A pair of Revision Sawfly performed slightly better as the insert was a better shape but still fogged up way too easily.
Either contact lenses or choose a pair of glasses that can be directly glazed.
@matbee
You could try Rudy Project. I've had a pair of Rydons with an RX insert from RXSport for several years and prescriptions. No issues with optics, fogging, comfort, or weight.
I like the look of the Rydons and love my growing collection of lenses, which would be much more expensive glazed.
I even use mine on vacation.
Weirdly i quite like glasses with the optical insert its just i wanted something a bit bigger like the jawbreakers
Im not a fan of contacts however if its wet i dont really have much choice as the inserts steam up
My experience of inserts with m frames was the same as mattbee.
my mate used some inserts in rudy projects at the same time, he was a lot happier with his.
but, c/l ftw, you can wear anything then.
