I can trace my intended route with my finger and it works out the distance? Preferably on (well to be honest, only) OS maps?
(Yes I realise I could do this with a bit of string/ruler and a map but don't always have such items to hand. And yes this has probably been asked before but I cba searching for it)
Thanks!
Used to be a cracking one.... but they closed it down 🙁
you can do that by creating routes on mapmyride - you need to usea mouse to add the points rather than tracing with your finger, but it will follow roads and footpaths and other rights of way that are marked on googe, or you can set it to just add points where you click
www.gmap-pedometer.com is what I use from time to time. google and OSM maps, but not OS, iirc.
just have to remember to turn off the snap to roads feature which is always on by default, and exprt to GPX is a bit of an art. there are probably better ones out there.
Thanks both above, ideally just looking to make a line with my finger/mouse. Had something on Memory Map that I used to use
You can do it on Bing maps. Though it's not obvious you can! Click on "My places" to display the window with the tool in it.
Don't want to export, just want to draw lines/routes to work out the distance
Ooh thanks mad Pierre, shall go look
Google Earth.
Oooh, I didn't know you could even look at OS maps on Bing! Had never bothered looking. Now firmly bookmarked!
If it's a road route then bikehike is great using the google maps snap to roads facility as it joins up your clicks using the roads available between the points so the number of clicks required is low. No good for offroad however.
Road?! *spits out tea*
Bike Hike + 1.
Google Map + OS + OpenCycleMap 😀
Untick the "Follow Road (google map)" box?
I see what you mean about dragging, but most apps won't have that feature these days as it won't generate waypoints properly for routing purposes.Thanks both above, ideally just looking to make a line with my finger/mouse. Had something on Memory Map that I used to use
Viewranger is really good for mobile devices, not least because it lets you download maps (paid for OS or free OSM) to be used offline.
I use [url= http://wtp2.appspot.com/wheresthepath.htm ]Where's the path 3[/url]
[quote=GrahamS said]Bike Hike + 1.
Sorry, I meant the minimal-click, app fills in the gaps functionality is no good for offroad 🙂 I use bikehike to put together offroad GPX routes, the combo of OS and google maps is ace. Especially with google maps in sat. mode to pick up some unmarked trails.
CaptainFlashheart - MemberOooh, I didn't know you could even look at OS maps on Bing! Had never bothered looking. Now firmly bookmarked!
Yeah - ever since they bought multimap.com donkeys ago.
You can draw routes, import .gpx files, pinpoint places and save them and link to 'em etc but most people don't seem to be aware?
Bing wins (as i can access that at work too)
Thanks all
Bike hike supports off-road pretty well - not quite as well as road, but it works well enough - it helps to switch to OSM mode, and change the options to use the 'Open Street Maps' routing option.
