Is everything out o...
[Closed] Is everything out of stock at Hope?
[#1593029]
Did the whole factory have a works outing to somewhere directly under the volcanic ash cloud for the last month - I cannot for the life of me find any hope hoops in stock, and if you want to see what a column of the phrase "out of stock" 10 lines high looks like, click on CRC custom build wheels.
I was after a front wheel with a pro 2 hub (20mm axle) with something like 721 rims - I'd even go for 717 or 321 rims. Looks like I'm going to have to go for a Pro 2 build with DT 4.2s for £92 quid.
If any kind soul sees what I was originally after in stock anywhere, let me know (not sure what the width of the 4.2 equates to in Shimano speak so hdifficult to compare - I'll keep looking)
Alternatively if someone tells me that the DT deal is a good one, I'm happy to be swayed.
Cheers all
Posted : 10/05/2010 5:30 pm
4.2 is similar to Mavic 717, not sure exactly what we've got in stock, but we've got a couple at Sunset. Give us a call tomorrow and i'll let you know-02920371321.
Posted : 10/05/2010 6:51 pm
avoid 4.2's, remember what happened to mine in morzine ? go for the 5.1's or the budget e540's (£10 a pop on CRC).
Posted : 10/05/2010 7:08 pm
 MSP
stans flow
Posted : 10/05/2010 7:10 pm
 tron
When I was looking for rims, the 5.1s had a very bad name compared to the 521s.
Posted : 10/05/2010 7:13 pm
 igm
Another for the Flow
Posted : 10/05/2010 7:33 pm
 Del
I have a wheel you can borrow in the meantime. try colin lewis in paignton for a build. they've just done a couple of wheels for a mate on pro 2, one of which was a 719 ( the other a clown size ).
Posted : 10/05/2010 7:38 pm
Cheers all - I'll try LBS - I really wanted a 721 rim so maybe keep looking.
Del, might take you up on that loaner - it's for Sonja not me so it should stay straight 🙂
Thanks Coatesy - just picked this up and will prob try local first, unless you have a 721. If I'm gonna wait I might as well get what I was originally planning on - Pro 2 on 721 with black spokes.
Doug
Posted : 12/05/2010 4:56 pm
