Internal dropper po...
[Closed] Internal dropper post cable rattling
[#11215289]
Anybody any tips on how to stop internal cables rattling my dropper post cable is constantly rattling anybody any tips that have worked? Read online that fading a pvc tube over the cable works anybody had any success with this method?
Posted : 28/05/2020 11:28 am
https://www.amazon.co.uk/Jagwire-ZSK600-Internal-Sleeves-Unisex/dp/B07C32KBG9
This is what I'd use, I'm getting a little rattling from my rear brake house in the internal routing tubes, may get around to putting the cables in this.
Posted : 28/05/2020 11:33 am
Yep, as about. Air con pipe insulation. Closed cell foam so it doesn't soak up water.
Posted : 28/05/2020 11:41 am
If you can cover postage I am happy to send you a length of the jag wire tubing I have lots left over from doing my bike.
Posted : 28/05/2020 12:02 pm
The other option is make a spider out of zip ties to go around the cable. This will stop the housing contacting the inner wall of the frame.
Posted : 28/05/2020 12:15 pm
