Internal Cable Rout...
[Closed] Internal Cable Routing (Cervelo)
 Haze
Anyone re-cabled or built up a 2014 R3 by any chance...or possibly S3?
Trying to find out if there are internal guides or if I need to get creative...
Posted : 24/04/2016 4:59 pm
Confused. 2014 R3 is externally routed (the silver colour frame). OTH the 2015 R3 is internally routed (black frame) and is a doddle. Just remove the plastic plate at the BB and feed the cable into the down tube.
Posted : 24/04/2016 5:43 pm
 Haze
2014 Ultegra (black) is internal, the silver is the 105?
Anyway, if I remove the plate I'm guessing it leaves an opening large enough to not have to worry about picking up the cable?
What about rear brake down the top tube?
Posted : 24/04/2016 6:14 pm
I ride a 2015 s3. The tt has routing so just thread the cable in. The down tube is hollow so be careful as it's easy to cross cables.
Posted : 24/04/2016 7:09 pm
It's dead easy.
The cable stops near the head tube pop out and the massive insert near the bb pops out meaning that there isn't too much threading to do.
Posted : 24/04/2016 9:37 pm
Thread and a hoover if there are no guides.
Posted : 24/04/2016 9:39 pm
 Haze
It's dead easy.
Cheers Sola, didn't fancy spending most of my evening poking around trying to find the exit. Will get cracking tonight...
Hoover trick never worked last time I tried.
Posted : 25/04/2016 6:11 am
With the down tube there is plenty of room once you pop off the incerts. I usually remove these and tape the new cable to the old one before pulling the old one out.
1 tape new cable to old and pull though.
2 remove new cable leaving old in the frame.
3 take new cable and thread through lever.
4 re- tape to old cable which is still in the frame.
5 pull old cable back though, dragging the new cable with it.
6 connect to mech and finish job.
Hope that' makes sense ๐Ÿ™‚
Posted : 25/04/2016 6:17 am
