Interesting headset...
[Closed] Interesting headset problem (tapered steerer, carbon 456)
[#2532854]
I built my C456 with 1 1/8 forks and a reducer head race. All perfect.
When I added the tapered steerer Revs, first ride the headset came very loose and I tightened it, but next ride it was making an odd 'cracking-clunking' noise but there was little or no play in it. I took the HS apart and thought it might have been something to do with the split tapered ring in the O-O headset. I checked it all, and put it back together as tight as possible, and also added a taller spacer above the stem just in case the top cap was grounding on the steerer.
Next ride, after a few miles and some bumps the cracking/knocking noise was back, I cranked the HS down as tight as I dared and it seemed to stop, then it came back again!! No play at all at this point, and I was worried the alloy insets the HS presses into were moving in the frame by now...
So I stripped the HS down again and the tapered ring in the HS was so tightly wedged between the steerer and the bearing I had to pry it out with a screwdriver, as I did so I could hear and feel the crack/creak noise! But no movement anywhere in the assembly.... Deffo the ring causing it...
So after a bit of examining it turns out the headtube on the frame is too short for the taper on the fork steerer! The tapered washer is not fitting between the bearing and the top of the taper on the steerer properly, and as it's not parallel with the taper of the steerer, and that's what's creaking
Crap pic to try and show the problem
[url= http://farm6.static.flickr.com/5057/5500334030_7dae114d52.jp g" target="_blank">http://farm6.static.flickr.com/5057/5500334030_7dae114d52.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/peter_atkin/5500334030/ ]Untitled[/url] by [url= http://www.flickr.com/people/peter_atkin/ ]PeterPoddy[/url], on Flickr
So, I've filed the inside of the tapered washer to a knife edge taper (Almost) itself, to match the steerer, and reduced the flange under the taper you see there to half that height, refitted it all with plenty of grease. In a garage test it seems OK, but another Peaks ride tomorrow will show if I'm right.
Anyway, the only real fix I can think of is a top headset race that's taller to move everything up higher away from the taper, but I'm wondering what might fit instead, it's just a normal top race, right???
Posted : 05/03/2011 8:35 pm
Bump for the weekday crowd, being as I seem to have stumped the weekenders!
UPDATE
The mods I made seem to have made a difference. I'm not 100% sure the headset is staying tight, but the crack/clunk noise didn't return after a days riding in the Peaks yesterday....
Posted : 07/03/2011 10:22 am
Surely the headtube on the frame is incorrectly made and therefore should be replaced by warranty?
Posted : 07/03/2011 10:29 am
I had some issues with the on-one smoothie and a standard 1 1/8" steerer - difficult to get it go tight and stay that way.
I did wonder whether the Alu inserts in the frame were slightly the wrong size (or the headset cups where the bearings rest in them). I did seem to have to tighten the top cap more than I have on other frames/headsets - not to the point the headset is 'tight' though.
Do they do a +10 or +20 bottom cup version of that headset - woudl adjust the geometry a bit but woudl solve the problem?
Dez, I'm not 100% sure that's so. I can imagine the conversation:
Me - Mr On One, your headtube is too short for a tapered steerer
Mr O O - No it's not. The taper on the steerer is too big
Me - Mr Rockshox, your taper is too long for my bike
Mr O O - No it's not. The headtube is too short
etc etc ad infinitum!
So, I'm in 2 minds as to weather to contact On One or not.....
Posted : 07/03/2011 10:34 am
Me and Cy@Cotic both noticed that there is not actually a specification for the taper on a tapered fork. There's a spec for the diameter at the base and the top, but not a spec for the length of the taper.
Ouch.
A better fix would be an "external" top cup?
Posted : 07/03/2011 10:39 am
Sounds like the short on-one headtube is just a teeensy bit too short for the steerer/headset combo. Although i see it is an on-one branded headset 😆 If you managed to rectify it by filing the inside of the wedge, there must have only been a few mm in it...
I wonder if manufacturers anticipated this arising?
Is there a 'standard' length of taper already set?
ie steerer returns to 1.125" by x mm above the crown, to allow frame and headset makers to plan their own parts.
Peter, what is the length of your headtube? How does that compare to short headtubes on 'normal' frames? Millie has had (small or laydeez) frames with 90-100mm headtubes before, it would be a shame to lose the option of making them so short becasue you wanted to put a tapered steerer in.
[edit] oh, i see lots of you beat me to all that. ^^ Must type faster.
wwaswas, as far as I can see, I'm 100% sure that gold headset taper ring is grounding out on the top of the taper of the steerer.
The only fix I can think of is a taller headset in one way or another, but I don't really want to do that as it'll cost £££ and I have a 7-8 ride old headset already in there.
I do have a King headset knocking around and I'm considering trying the top race from that (No expander wedge in it see!) but I'm a tart and I have a nice looking bike, and I don't want to have a clumpy looking mixed headset and then there's the old 'King HS score steerers thing' as well, and these are 150mm Revs..... 😕
Posted : 07/03/2011 10:40 am
Contact them they may have a suggestion.
Brant, thanks for the advice, I think you're on the same lines as my thinking, but I'm not too familiar with different types of headset. Is that a semi-integrated? What headset are you thinking of? Hope?
Posted : 07/03/2011 10:42 am
Brick, I think I'll drop O-O an email at some point...
I can't believe I'm the only person to have this problem, surely not????
Yep, that's it. I reckon there's 2mm, maybe 3mm in it....
Posted : 07/03/2011 10:44 am
 cy
Sorry to see you're having trouble. As Brant says, there's not actually any industry standard as far as we're aware for this. I guess Trek must have tied something down when it was developed, but it's not in the public domain. Only thing I've seen are Fox fork drawings which has a maximum taper length of 95mm from crown seat to taper top. I've not seen any Rock Shox drawings, so I don't know if they conform to this.
With an external cup headset like that with a stack of around 12mm, your head tube would need to be at least 90mm long to fit a Fox fork once you account for top cup clearances. How long's the head tube on that frame?
Posted : 07/03/2011 10:58 am
Was this new 'standard' created by the same remarkable brains that put together the latest CEN tests? 😉
Posted : 07/03/2011 11:07 am
Cy, I don't know how long the HT is and I'm 100 miles away from the frame until tomorrow night, so I can't measure it quickly...
But it's a 16in frame which equates to a medium on this table here:
http://www.on-one.co.uk/i/q/FTOOC456MIX/on-one-carbon-456-stick-n-mix-frame-bundle
So it SHOULD be 105mm......
Forks are 150mm Rockshox Revelation RLTs
Thanks for the help, there's no need to say sorry though, it's not your design!!! 🙂
Posted : 07/03/2011 11:11 am
Just measured my 18" frame and it's 105mm.
Posted : 07/03/2011 11:14 am
wwaswas, yes the 16 & 18in frames are listed as 105mm headtubes, so mine should be the same....
Posted : 07/03/2011 11:16 am
[i]Me and Cy@Cotic both noticed that there is not actually a specification for the taper on a tapered fork. [/i]
Man, that is moronic. Trust the bike industry to bring in "standards" that have no standards!!
So glad I have no desire for a new bike (yet)!
I guess Brant is saying that any external headset cup on the top would be high enough up the steerer and mean the 1 1/8th wedge would then fit. Seems to make sense.
Posted : 07/03/2011 11:19 am
Dez, so that's a semi-integrated top cup I have in there yes?
I can just see it looking like a right old lash-up, but I do have a spare FSA top race I can try I think....
It's not good, is it?
I bloody love that bike, it's a flipping hoot to ride, and this is really taking the shine off it right now, but as far as I can see, it's not On One's fault and it's not Rockshox fault. It's just a bunch of arse.
Posted : 07/03/2011 11:23 am
Pretty sure it is - as far as I've worked out (only ever actually [i]used[/i] external headsets), integrated means the bearings are mounted in the frame, semi-integrated have a low pro cup with the bearings 'inside' the frame.
Could be wrong about integrated though!
Posted : 07/03/2011 11:28 am
You can't go having a thread on here and not flame someone in a pointless and improper manner! There are standards to uphold around here you know. Get with it and pick a target - any one - you have mentioned a few!
The easiest solution would probably be to get a thicker crown race made up. On One really should release a solution to this themselves.
Posted : 07/03/2011 11:29 am
Flip, there are [b]5[/b] types now!
http://www.canecreek.com/tech-headsets?view=standards
 LoCo
ok tootall, I dislike the radius on the piping in the background of the picture, there, happy now?
Interesting issue pp not some thing I've come across as yet but then my frame are of the 'gate' variety being a lanky begger.
Posted : 07/03/2011 11:34 am
That's my Brother's cellar! How VERY dare you!!! 😉
Andyl, yep, you're right. Where the hell do I get one of those then?
I'm gonna try a different top cup and see when I get the chance, which will be at least Friday, sadly.
No point in effing and jeffing about this, it won't fix the problem. I'm sure it's doable though. I just want it to look neat!
Posted : 07/03/2011 11:42 am
Dez, thanks for the link.
This headset covers 2 of those standards!
I think the top cup is a 'Zero Stack' from the description:
[i]The Zero Stack design offers a low stack height and the security of bearing cups that are hidden inside the head tube. ZS cups are compatible only with specifically machined head tubes and cannot be retrofitted to an existing bike with Traditional headset cups[/i]
I'm now wondering if a normal top cup will actually fit? 😕
Posted : 07/03/2011 11:46 am
Yep: zero-stack = Semi-integrated (hey, why have naming standards if we can't have size standards!)
Good point - the cup might actually be too small. Blimmin flip, what a palava!
Posted : 07/03/2011 11:56 am
angle grinder on the fork steerer time?
Posted : 07/03/2011 11:58 am
The C456 top is 44mm so it is too big for a 'normal' ie 1 1/8th headset top cup.
I wonder if one of the new 44mm external fittings might fit though?
Nukeproof do a range: http://www.shedfire.com/2011/02/19/nukeproof-warhead-headsets/
They have external lower and upper cup options - no idea if they will fit. The external upper would be for 1 1/8th steerer section but look to have a chamfer, the external lower are flush fit which might be better and you would need the straight 1 1/8th tube one but that is a lot of money to splash out to fix a problem which should not exist.
A crown race should be pretty easy to get made, you know the angle on the bearing fitting (written on the bearing) and the internal diameter should be standard (or give the place the old one to measure and tell them it is a press fit). I would get it made out of aluminium though instead of steel to save weight and get it made +5mm.
Another option would be a ring that fits over the existing crown race with a lower inner taper and upper external taper so it works as a crown race spacer. I was messing around with the crown races on my superstar headset (comes with both 1 1/8th and 1.5" lower crown races) doing something similar. Would want a properly machined one to use it though. A bit of Loctite bearing fit would probably be wise on the crown race to spacer interface too.
Posted : 07/03/2011 12:01 pm
Dez, yes, I suspect you are right.
New Question:
See that gold alloy taper ring in my pic up there? Well it seems the problem is that it can't seat properly becasue of the small vertical flange below the taper. I've already modified that flange, but whaddaya think would happen if I removed it entirely?
My thinking is that there would ne nothing to get jammed between the bearing and the steerer, and the taper would sit properly where it should on the bearing, with the only issue being (still) the inside face of is not sitting squarely on the steerer.
Can anyone think of any downfalls of removing that flange entirely?
Posted : 07/03/2011 12:04 pm
Andy, thanks for confirming my suspicions! 🙂
This has crossed my mind too. I reckon to be safe I'd need to pinch 3mm in total. 1mm spacers under each cup and a 1mm spacer under the crown race would do this, but again, I need to get the spacers. And I'm not 100% sure it's a good idea to have the headset not fully inserted into the frame either....
Posted : 07/03/2011 12:10 pm
[i]any downfalls of removing that flange entirely? [/i]
it's designed to fit between the bearing shell and the steerer - if it's not there the steerer would be 'loose' in the shell and you'd be relying wholly on tension fromt he angled bit to locate the steerer in the bearing which doesn't sound like 'a good thing'.
I'm sure on-one must have fitted some tapered forks to one of these frames (albeit that the complete bikes run std tubes) - might be worth just calling them?
Posted : 07/03/2011 12:14 pm
This though:
[i]"Me - Mr On One, your headtube is too short for a tapered steerer
Mr O O - No it's not. The headtube is too short"[/i]
You - well which fork can I fit? And why wasn't I informed I couldn't fit RS forks?
Doesn't help, but it's bloody ridiculous! On-One need to know so that other purchases [i]are[/i] informed.
Posted : 07/03/2011 12:15 pm
Just called O-O, waiting for a call back
Posted : 07/03/2011 12:21 pm
Yeah you could use 1mm spacers between the frame and the cups top and bottom but I would prefer a thicker crown race.
As for the top ring thing - you need that for the bearing pre-load - this is an important part of the headset.
IMO On One should remedy the situation by releasing an updated part - either a thicker crown race, a deeper lower cup or a slightly less flush upper cup.
Did you get the headtube faced at all? The On One documentation for the C456 is pi$$ poor and they have really annoyed me about it. I did eventually see a mention (either on their site or on their facebook page) that there is no need to face the BB and headtubes - I didn't anyway as my reasoning was they are purpose made fittings so not just tube as part of a welded frame. There is still the chance the head tube fittings are not square though as they are 2 parts. But I don't fancy letting anyone loose on my carbon frame with a serrated facing tool!
I tried asking On One on their frame page (in the comments) if a top swing front mech was okay to use. The guy replied about bottom cable runs acting as though I was a bit special in asking if it was top or bottom pull - what I actually asked was if you had to use a conventional mech or if I could use my top swing one. I have the top swing on but I am not convinced the frame is the right diameter that close to the BB area.
Posted : 07/03/2011 12:26 pm
No, thank God!
Yes I know that. I'm asking if I can modify it, not remove it! 🙂
Posted : 07/03/2011 12:33 pm
ahh I see. hmm, dunno. Might stop it sitting right. Got any old ones with the same bearing angle that you could modify?
Posted : 07/03/2011 12:41 pm
I'm gonna have a faff when I get the time later this week, but I'll see what O-O say first!
Posted : 07/03/2011 12:42 pm
To me it seems odd that you should have to faff.
I had a not to dissimilar experience with a frame recently.
Problem could have been caused by three separate parts and suppliers.
Talked through the problem with the frame builder/supplier and the problem was solved with a replacement frame (under warranty).
The case is question was a little different and I don't know how O-O could resolve this by swapping out the frame. But they should be able to offer a solution that works.
As said ^^ surely you are not the only one who has experience this as the RS fork is a popular one.
Interested to hear how you get on.
Posted : 07/03/2011 12:51 pm
Yeah. You'd think, wouldn't you?
I don't have to. But I like to, and if O-O can't sort it maybe I can. 🙂
To be clear it's not a massive problem, I can ride the bike as is, but it's not 'right' and that bothers me. I can feel something is wrong when I look for it, so it needs to be fixed.
I can well imagine certain people never even spotting this if it occoured to them!
Posted : 07/03/2011 12:59 pm
I would guess that the reason why this hasn't cropped up before is that most people are using 1+1/8th" non-tapered forks, that's what I've fitted, simply to make swapping forks to my other bikes easier.
Posted : 07/03/2011 1:15 pm
Paul, I can't believe I'm the first person to fit a tapered fork to a 456. Sorry, I just don't believe it. If O-O haven't done it, and tested it, then they should be shot.
Posted : 07/03/2011 1:16 pm
yeah I am using a 1 1/8th too. Going to be very annoyed if when I come to fit a tapered one it won't fit. I am using a superstar headset as it was lighter and came with both crown races so it's going to be a shame if the tapered fork still wont fit due to the short head tube.
The short headtube does mean you can buy forks with really cut down steerers nuce and cheap but it means you have to run lots of spacers if you don't want to cut your steerer which spoils the look.
Posted : 07/03/2011 1:19 pm
PeterPoddy - Member
You are taking a very positive line on this one.
I acknowledge that its not a massive problem but I guess regardless of that it should not be happening.
It was the constant little niggle that led me to finally getting mine sorted.
Now that it is I love my frame even more 😀
Any news from O-O?
Posted : 07/03/2011 1:20 pm
PS if you do resort to getting a new crown race made then give Hope a shout. They might make a run of them to sell to similarly stuck C456 owners.
Posted : 07/03/2011 1:22 pm
No. It shouldn't. It's a combination of poorly thought out 'standards' that aren't working together when there should be no problem at all.
I'm gonna be a bit more than miffed if I have to spend money on this, to be honest, but chucking a strop gets you nowhere fast I find.
It's a problem. A solution can be found and everyone can learn from it, hopefully..........
(That's pie in the sky isn't it? 😉 )
Posted : 07/03/2011 1:29 pm
Page 1 / 3
