Intense Tracer bear...
[Closed] Intense Tracer bearing replacement
[#2351049]
Guys,
Anyone got the instructions for bearing replacement on a tracer?
Particularly interested in the torque settings, a couple of my bearing bolts have come loose
Posted : 09/01/2011 6:43 pm
I'm sure you can find the torque setting on the intense web site, as for changing the bearings big hammer and a srew driver work well. I personally use a home made press and a touch of loctite retainer when fitting new bearings. If you need pictures of the press to give you some ideas then let me know.
Posted : 09/01/2011 7:23 pm
Cheers lipseal I'll check the intense site, bloody bearings this is the result of a creak from new the LBS have striped all the bearings down to clean and grease, creak gone but the bolts are creeping loose.
Posted : 09/01/2011 8:11 pm
Apparently they should be 7lbs
http://forums.mtbr.com/showthread.php?t=30815
Posted : 09/01/2011 8:33 pm
Lipseal,
Any chance of some pics of your bearing press, gona give it a go
Cheers mike
Posted : 18/01/2011 4:29 pm
Ok will get some up later or email.
Posted : 18/01/2011 6:07 pm
Sorry about the quality, as you can see I have managed to get my hands on some nylon, aluminium and big washers, any sort of flat plate will do hope this give you some ideas.
Posted : 18/01/2011 8:08 pm
Spot on mate thanks for that
Posted : 19/01/2011 6:51 pm
