Increasing Rockshox...
[Closed] Increasing Rockshox fork travel on hardtail
My winter bike is a Boardman Pro 29er from 2014. It's rather lovely, but I noticed that the new version of the bike has got 120 mm of travel, instead of 100 mm on mine. The frame looks almost identical, so I thought (as the fork is due for a service) that I might increase travel to 120 mm, which would also help the geometry a bit. I'd probably need new parts. Any advice? Issues? Best place to have it done? Fork is a Reba RLT. Thanks!
Posted : 27/02/2017 11:30 pm
Solo air? Should just be a matter of changing the air shaft although some rebas won't go the full 120mm
I got about 115mm out of mine due to the dampening shaft being too short.
Posted : 28/02/2017 3:24 am
Should just need to remove the All Travel spacer. As long as the air shaft is ok, and it should be on a Reba.
Check the service manuals on the SRAM site
Posted : 28/02/2017 7:08 am
No travel spacers in 2014. They switched to Solo air in 2013 so you would need a new air spring shaft (about £20).
Is your fork QR or 15mm? Only the 15mm is supposed to be upgraded and you should have 3 sets of sag markers on the stanchion - 80, 100 and 120mm (at about 80% sag when full extended in 100mm travel mode.
Posted : 28/02/2017 7:20 am
Thanks! It's 15 mm so I will just get a new air spring shaft.
Posted : 28/02/2017 8:56 pm
