we'll give up on trying to add pictures then! 😆
ok guys what did I do wrong then?
That looks smart! Crying out for gold headset spacers and a gold seat QR.
I like that, looks good in black.
EDIT: double postitis
DarrenH - Member
on the last [img ] you need to put a / before the i like [/img]
so the picture is [ i m g ]......jpg[ / i m g ]
tom
Thanks guys!
Rear derailleur needs tweeking and a big thank you to graham of slam 69
for fitting the forks and shortening the brake hoses.
thanks taka
No! That's a nice tasteful build, none of that nonsense!
Very nice.
lovely build
Front QR lever wants setting 180 degrees the other way so it can't undo by snagging on something whilst riding, rear could be better too
Saddle wants to be flat (for XC riding presumably?)
Stem looks a bit short and uppity (making the bars higher than the saddle at pedalling height and generally reducing breathing space)
Conti Verticals are only available in wire aren't they, seem a bit cheap/heavy/etc when the bike has XT cranks and fox forks (though not quite fox/xt level frame all things considered either)
Otherwise, all very nice, I'd quite like an inbred
SpokesCycles - MemberThat looks smart! Crying out for gold headset spacers and a gold seat QR.
Ill second that! Very Nice build!
well done.
And how does it ride then ?
Just got back from my second ride on it takisawa2, bloody excellent!
Really zips around bends and stuff, also very easy to get off the ground 🙂
Seems a lot less twitchy than my rockhopper, which gave me a lot more confidence to really give it some on the descents etc.
Climbs ok, but not much worse than my hopper.
Good choice. Looks a bit like mine 😀 :
Is that an On One seat QR? Mine lasted about 3 months before the plastic bush disintegrated. On One have now changed the description as at the time it as described as brass.....
I bought a 30.0 Hope one (gold obviouly) & it's loads better. I also got some NC-17 lock-on grips from CRC that are brown with gold clamps and look quite good.
Have fun on it!!
Nice looking bike.
stumpy, I've just got the standard allen bolt seatpost clamp at the moment.
I'll probably get the hope qr one when I've got money available!
Which diameter size should I be looking for btw?
DarrenH - Member
I got the Hope 30.0 diameter one. You really want 29.8mm, but it's not that common and 30.0 works just fine.
Only difference I have noticed is that when the clamp is released, the QR does swivel more easily on the frame, but it's not really an issue.
Not had the Hope one long but it very smooth, seems secure & has a decent quality brass bush.
I got mine from Noah's Ark for £17 and they delivered it really quick. I definitely recommend them.
here here!!
none of that blingy pap here please, this is a respectable thread
