Can the STW massive point me in the direction of an idiots guide to change my Reba Team 29er from 100mm to 80mm. I'm thinking of a how to guide like PeterPoddy's guide to replacing my poplock with a fork leg lockout. Surely it cant be that hard even for a workshop virgin
Much appreciated
This months mbuk has a section on it with full instructions.
Adding a spacer to the air leg is dead easy and requires no fluids if you're careful - do it when you're cleaning the seals.
But replacing the poplock's remote for a leg-top is a lot more work as it requires a replacement assembly in the damping leg. Although I believe some people don't bother with changing that... Don't know how well the lock-out would work then...
forum search is a wonderful thing...
[url= https://docs.google.com/fileview?id=0B1AoGIWBz4H1M2E5ZTc0MTItNjM4NS00YjBiLWEwZDgtMjEyYTQ5NWZlMjc5&hl=en&pli=1 ]here you go[/url]
