Hi
Anybody ride one of these?
If so how tall are you and what size do you ride and what length stem do you use.
Steve
174cm medium, 70mm.
Spot on.
5'8" which I think is 170cm, ride a medium with 50mm stem. Perfect for me.
181cm. 70mm stem. Size large.
178cm, 50mm stem and large frame
I'm 6ft and wasn't sure between large and extra large.
Tending toward large now
Thanks
Steve
180cm, 50mm stem, 760mm bars, lrg.
Cheers all
Found a large 2014 model reduced to £1500 so couldn't resist.
It'll be here in a couple of days
Steve
Ok next question to get me on my way!
Weight and shock pressure please?
Also reading the reviews it states the shock can be left fully open most of the time-it's a Fox CTD so I guess that means in D mode.
Do you agree? Any other setting advice gratefully received.
Steve
