any pointers?
on the back of one of the legs gives a starting point, (or at least one mine they do)
Dave
whatever the pressure turns out to be to get the sag at the level you like.
Its not very technical.
Download the pdf from Rockshox as a guide and tune to suit you.
Hi
I am just under 13 stone and I run mine much softer than recommended.
100psi in positive and negative is spot on for me.
Steve
12 1/4 st, for my 09' 140 revs i use 110 + and -, a bit less in the '10 versions but couldn't explain why..
black box / team versions can be run softer (100) as the damping props up the front a bit more.
As has been said, whatever pressure it takes to acheive 25% sag...
Remember to remove the pump when 'testing' the sag though, or it'll change the result.
DrP
