I S to post rear ca...
[Closed] I S to post rear caliper mount
[#1629520]
I have a hope M4 rear IS caliper to go on a new frame with rear post mount fitting, are there any mounts available, all the stuff listed on CRC only covers post caliper to IS ??
Pete
Posted : 21/05/2010 7:28 am
I have never ever, seen a post mount frame, are you sure about that?
If it is a post mount to IS caliper you want, your right not many companies make them, but Hope do. I have a post mount fork running an M4 is caliper, its a bagstard to set though as the caliper gets in the way of doing up the post mount bolts, but it is doable..
Posted : 21/05/2010 7:38 am
Yup, new 5 spot has rear post mount.
Posted : 21/05/2010 7:46 am
Then you need that Hope bracket, and if you have the ball end allen keys you will have found their ideal habitat.
I cant remember where mine came from, I think CRC listed it but where out of stock...
Posted : 21/05/2010 7:48 am
