Ripped the bead off a Conti Trail King 2.2 today, followed quickly by bits of my knees and elbows.
Trashed a Bonty XR4 shortly before that.
Apart from a skills course, any other similarly specced tyres I should be thinking about (tubeless on flows)?
The conti was it tubeless
I love them but you can't run tubeless as the side walls are very thin
My conti Protection are both tubeless front and rear and both are fine.
The protection are but the standards are not.
The default answer is a Minion DHF EXO TR
Did both tyres fail at the bead? Could you have a sharp-edged to your rim in conjunction with a "too low" tyre pressure?
I've been running various conti protections tubeless for 5 years without catastrophic sidewall failure. They do take a while to fully seal up though. But I agree, the sidewalls are thin, and all of mine do show signs of wear but have never failed.
That's interesting. It was sold as TLR but I had noticed persistent micro-ooze of Stans all the way round the sidewall. They were't losing much pressure but I was going to ask on here if I should be returning them. I just managed to destroy it first 🙂
Did both tyres fail at the bead? Could you have a sharp-edged to your rim?
No - XR4 was a sidewall slash that I couldn't repair.
Haven't got around to checking the rim this time around. It's possible it was a burp with the damage happening afterwards - there were some rocks, but it was high speed setting up for a flat corner.
