Hydraulic hose join...
[Closed] Hydraulic hose joiner/ repair
[#11480764]
the hydraulic hose on my cargo bike (think tandem length) has a weeping nik about halfway along.
id prefer to not strip the hose out and replace i f possible and repair where it is, can’t for the life of me find any inline repair apart from the ticycles one in the U.s.
anyone done similar?
I do have spare shimano threaded collars barbs and olives but can’t find a coupler as not sure on thread
Its shimano 5mm but obviously will use any fitting that works.
Tia
Posted : 15/11/2020 10:46 am
You need the shimano easy joint thingies. Not sure if they're available aftermarket though. I'll dig out my cx bike and see if there is a part number on them.
Posted : 15/11/2020 10:56 am
No part number, just says Shimano on them. Sorry.
Posted : 15/11/2020 10:59 am
Cheers Simon, I’ve seen them mentioned but no part numbers to be found.
think they’re known as j-kit or easy joint. Would be amazing if they are available aftermarket.
Posted : 15/11/2020 12:28 pm
Yep, they're J-kits, and as I found out when we sent a faulty lever back with one fitted, they don't seem to be available seperately (and they have a crimped end on a short hose, so unlikely to be much use unless the nick is very near the end). It may be worth speaking to your local hydraulics supplier/specialist.
Posted : 15/11/2020 1:01 pm
https://www.sjscycles.co.uk/brakes/100-dry-hydraulic-coupling-fittings-no-hose-supplied/
any good? Its not really the right solution. I would replace the entire hose
Posted : 15/11/2020 1:05 pm
SM-BH59-JK straight connection hose for ST-RS685/BR-RS785 says it comes with 2 removable inline fittings.
https://www.freewheel.co.uk/shimano-ultegra-sm-bh59-jk-straight-connection-hose-for-st-rs685-br-rs785-rear-1700mm-black-smbh59jkssrl
Posted : 15/11/2020 1:21 pm
 K
I can look at making some if you can't find anything suitable.
Posted : 15/11/2020 1:56 pm
Cheers K, I’ve now bitten the bullet and decided to replace the whole line as it’s still cheaper than various other options.
the hydraulic dry coupler being particularly pricey.
i still think there’s a market for a repair connection for anyone but $22 plus import etc is too rich for me.
thanks for everyone’s advice and help
Posted : 16/11/2020 11:42 am
