Hydraulic gears, wh...
[Closed] Hydraulic gears, why not?
TJ, I thought that one of the significant problems with the Tesi was engine-generated heat rather than ambient?
Posted : 29/10/2010 5:09 pm
I thought it was a bad idea to lube cables??
I use SP41 cable outer (5 metres is 30 quid or something) and stainless steel inners. Fit dry with no lube and they last 1-2 years before needing replacement.
Posted : 29/10/2010 5:38 pm
K.I.S.S.
http://www.chainreactioncycles.com/Models.aspx?ModelID=3318
Posted : 29/10/2010 5:39 pm
I prefer no-lube myself.
Posted : 29/10/2010 5:41 pm
Some cables that have the teflon liners don't need lube and if you do lube them it must be a compatible lube. I prefer basic cables and lube 'em( I wrongly put teflon outer that don't need lubing above rather than teflon coated inners)
Posted : 29/10/2010 6:00 pm
 mrmo
Again, a moot point - I'm sure it at comparable weight at a cost, but that cost would be mental. Speaking of mental costs, the Rot5 setup appears to be using reltively thin plastic hose. I have no idea what the comparable weight per m of two runs of that full of fluid is compared to a steel reinforced brake cable outer with a steel cable in it.
That is why Nokon on do carbon cables. others do polyamide cables etc
Posted : 29/10/2010 6:35 pm
A lot of people here have enough trouble bleeding brakes, imagine the fun they'd have bleeding gears.
Posted : 29/10/2010 7:22 pm
Makes no sense at all! Hydraulic systems are good for high force but not for precision movements. Look at what they're normally used in - brakes and rams! If you use them with tiny gearboxes you'll need electronic systems to keep them calibrated in which case you might as well use electrics to deliver the shifting force.
Posted : 29/10/2010 7:29 pm
Fine on a road bike maybe. Cover in mud and neglect = bad. I'm not too sure that I would agree with the fact that hydraulics aren't suitable for gears. If they weren't then why would they appear on the most precision sensitive user actuated moving part on the bike? The brakes.
Posted : 01/11/2010 2:41 pm
TandemJeremy - Member
Any modern cables of decent quality will be teflon lined, gear or brake.
Posted : 01/11/2010 2:47 pm
But you don't use indexed brakes. The derailleurs have to move large distances but stop precisely at predetermined intervals without the help of a human to 'modulate' them.
Posted : 01/11/2010 2:57 pm
I'll tell you the main reaon it'll never happen - Price.
Look how much you can by a REALLY cheap mech for these days - Well under £10. They are simple, built from hunks of cheap metal and can be made for bobbins. Even an XTR mech is only refined version of a cheap SIS mech when it comes down to it. Easy to make. Cheap to make. Big profit margin.
Now look how much a basic hydraulic disc brake is, and how many components there are in it. And, remember, the lever needs to work with the caliper, so they are supplied as a set. As hydraulic gears would have to be.....
So what you'll never get is volume production due to the cost, so there'll never be as much profit as a simple, tried and tested, cable set up.
And remember, hydraulic discs were a big lep foreward in performance for every rider. And when they were new they stood out, so everyone wanted them on their bikes to keep up with the Jonses. So people were happy to spend the money for the gains they gave.
Hydraulc gears will look pretty much the same, and work exactly the same as cables, so they'll be harder to sell to the riding public.
Electronic shifting has been out for years but never really got anywhere. I doubt hydraulics will ever get that far, if at all.
Posted : 01/11/2010 3:08 pm
cynic al - nope - I do know the difference. I suggest yo check it. Basic outer cable is not teflon lined.
Posted : 01/11/2010 3:13 pm
Sure, maybe for starters they could make a hydraulic 'lever' resemble something along the lines of a thumb shifter. Linear, no ratchet rubbish etc. The lever moves with full freedom until a plate is forced against it giving some resistance in the part that it needs to be.
Posted : 04/11/2010 10:29 am
TJ - oh well I guess I define "decent quality" as teflon lined - I've only seen unlined cables on the cheapest of bikes, and even then not for many years.
Posted : 04/11/2010 10:33 am
Good points and more than likely the reason. There are profits to be made though. I would personally love a set.
You're wrong to consider them to be the same and dismiss them because of this. Imagine the difference in cable discs to hydraulic ones. Immense. There would be minimal friction, minimum maintenance, hardly any cost after the initial outlay (which cannot be said for cables - if you kept the hydraulic shifter and derailleur for 4 years that could be a saving of £80).
Posted : 04/11/2010 10:34 am
Page 2 / 2
