Hub end caps- are t...
[Closed] Hub end caps- are they interchangeable?
[#7484369]
I'm trying to stiffen up my QR forks. I have DT240s hubs, RS Revs forks. I've managed to get hold of a 9mm skewer from the classifieds but not end caps. Hope end caps are available- does anyone have any knowledge or experiences of using Hope caps in DT hubs?
Posted : 28/11/2015 4:31 pm
No - you need the DT ones.
I've just drilled mine out in the past.
Posted : 28/11/2015 4:56 pm
Ooooh- can I just drill out my current end caps then?
Posted : 28/11/2015 5:34 pm
If you're careful aye.
Posted : 28/11/2015 5:37 pm
Cheers for that. A 9mm drill I'm thinking.
Posted : 28/11/2015 5:55 pm
I worked up to a 9mm to help get it centred.
Posted : 28/11/2015 6:07 pm
 jimw
If you do ever go for the proper caps, they are different between the 6 bolt and centrelock hubs so make sure you get the right ones.
Take it steady with the drill. Do you have access to a lathe-it is more likely to stay in the centre that way
Posted : 28/11/2015 9:49 pm
I can access a lathe at work.
Posted : 28/11/2015 10:18 pm
