hub and cassette co...
[Closed] hub and cassette compatability
Hi All, Before the parts arrive, can anyone clarify for me whether I will need a spacer behind the cassette to fit a 10sp Ultegra cassette to a Hope RS 4 free hub please?
If so, is the spacer likely to arrive with the cassette?
Posted : 18/01/2018 9:11 am
1. not sure
2. yes
Posted : 18/01/2018 9:20 am
Yeah spacer needed
Posted : 18/01/2018 9:34 am
You'll need 2 spacers. A 1mm spacer that comes with the cassette and an 11spd spacer that will come with the wheel.
Thanks guys. Do they both go behind the cassette?
Posted : 18/01/2018 9:35 am
Yes.
You need the spacer Hope should have supplied because the hub is 11speed road compatible and needs a spacer for anything that isn’t 11speed Road (including 11sp mtb which is standard 10sp length). You need the spacer Shimano should supply because it’s needed to properly fit s 10sp Road cassette. Both go behind the cassette.
Posted : 18/01/2018 7:45 pm
