How to remove the r...
[Closed] How to remove the rear axle from a SunRingle Ryde XMB hub?
I can't do it! ๐Ÿ˜•
Got the cassette off and the alloy end cap from the non-drive side. I presumed you can then tap the axle out, but no, it moves 1cm or so then stops. Taking the hex nut and bearing off the drive side seems the only way to progress but there's nothing to purchase on when undoing said nut...
Posted : 05/10/2014 8:15 am
