How to bleed older ...
[Closed] How to bleed older xtr disc brakes?
A mate has got some xtr dual control rapid rise on his bike, they must be a few years old and I'm sure there is air in the system so going to try and give them a bleed. We turned the bike upside down to take wheels out and the levers were spongy after. Have zip tied the brake levers to the bars to see if that'll help.
I forgot to look for the model number so I can see if there's a vid guide or can talk me through it, anyone know it?
I'm guessing that you bleed from the caliper up but it's a different process to the newer types.
TIA
Posted : 19/09/2012 8:34 pm
Ideally get a Shimano Bleeding-Kit TL-BT03
Posted : 19/09/2012 9:09 pm
Bleed from calliper up, then use the lever to flush fluid back through the system and vent it via the bleed nipple.
If you need any additional help give us a nudge here:
http://www.epicbleedsolutions.com
Posted : 20/09/2012 10:55 pm
I think his brakes are M965s which they say you do a conventional bleed from the top down?
Posted : 21/09/2012 12:12 pm
