How to adjust my Ch...
[Closed] How to adjust my Chumba's EBB?
 los
Do I need a tool or am I just being one?
A cursory glance over my new Chumba HX1 frame revealed no obvious means of rotating and securing the EBB. Other EBB frames I've seen have had bolts underneath but this doesn't.
I've heard people mention EBB tools - will I need one?
Los
Posted : 27/10/2011 12:35 pm
Have you called Si at Progressive?
Posted : 27/10/2011 12:37 pm
Obviously ensure the wedge is loose......then insert two allens keys in the holes on the side and some kind of bar between the two to allow you to lever the BB round inside the shell(screwdriver works well). If you can when rotating the EBB and tightening the chain try and get the wedge betweenthe 6 and 12 p'clock position....so if it does slip (and from my experience it will) it will at least tighten the chain in the process.
I've had lots of EBBs.........effin hate them, but sometimes you just have to endure the pain!!
Posted : 27/10/2011 12:40 pm
 los
Thanks, will give that a go (and chat to Si as well)
Posted : 27/10/2011 12:42 pm
There is probably a pin spanner you can get to rotate it. I have one for the EBB on my tandem. loosen the bolt holding the taper wedge, shock it with a hammer and punch to loosen the taper, rotate with pin spanner until the chain is tight, tighten bolt.
Posted : 27/10/2011 12:59 pm
[url= http://http://www.salsacycles.com/pdf/SalsaJuanSoloInstr.pdf ]Clicky go looky[/url]
Posted : 27/10/2011 1:41 pm
Just a thought on this, when installing the or any EBB to work with a geared bike, whats the best position to set it in?
Posted : 28/10/2011 8:23 am
Blimey, thanks for the link steve_b77
No chance in hell would I have realised that the side labelled 'R' is for the left hand side of the bike...
(The R stands for Righthand thread..)
Posted : 28/10/2011 8:41 am
[i]loosen the bolt holding the taper wedge, shock it with a hammer and punch to loosen the taper[/i]
my Gary Fishers EBB had a second nut that the bolt holding the wedge undid against - effectively the wedge was self extracting.
Posted : 28/10/2011 8:45 am
look on the non drive side
one of the holes is for loosening the EBB with a 5mm hex
loosen it
move it easily - use the hex to lever it does not take much
Posted : 28/10/2011 9:25 am
Whatever you like best?
Posted : 28/10/2011 9:28 am
