How thin is too thi...
[Closed] How thin is too thin
 Duc
[#837177]
Any idea how I can work out what the thinnest tyre I can put on a rim is ?
I'm converting a set of On One 29er wheels purely for road use and want to stick roadie tyres on as the commute they will be used for is a straight road run.
Posted : 03/09/2009 8:30 pm
I've run vredestein s-lick 1.25" on 717's before and they're plenty fat for poor roads. You'd probably be able to go to 1" easily enough I guess.
Posted : 03/09/2009 9:02 pm
Mavic recommend a minimum of 28mm on a 17mm rim.
Posted : 03/09/2009 9:08 pm
I've happily run a 1" tyre on a 717 in the past if that helps?
Posted : 03/09/2009 9:42 pm
