How many of us use ...
[Closed] How many of us use internal gear hubs for MTBing?
A frame mounted IGH, you say?…
https://flic.kr/p/fAAN3h
Moved on to pastures new now, but still owned by a forum member (I think)
Posted : 14/10/2019 1:58 pm
One thing to keep on top of with the Alfine 8 is the gear cable. I thought my cable was fine but the hub felt a bit draggy and clunky. I stripped it down intending to service the internals but when I opened it up it was pristine so I just closed it up again without touching it. I replaced the cables and it's much better.
Posted : 14/10/2019 2:05 pm
Got a Di2 Alfine 8 on the commuter, wouldn't fancy it off-road. Gear shift bit is OK, hub bit less good (bearings and stuff not up to Hope standard) and just really odd weight distribution.
I have both geared and SS MTBs.
Posted : 14/10/2019 2:33 pm
I do also have a c456 with an Alfine 8 on it. Use it for off road commuting and local rides. Apart from the first ride to get used to the weight change, it's been fine and I ride it like any other bike off road.
Posted : 14/10/2019 2:54 pm
null
Posted : 14/10/2019 7:00 pm
Rohloffs: Got 2.
First one I bought 2004, rode it for about 500 miles but quickly returned to single speed. Couldn't stand the coffee grinder noises in low gear (slight hyperbole). Still got it lying around somewhere.
Second one. Bought secondhand so it's seen some use. Much nicer. Used it in the WEMBO 24 Hour Ft William last year. Was amazed how easy the hills were in comparison to SS (I know, dumb).
I strongly dislike the gear change on them though.
My brother has one with close to 50,000 miles on it that he's used for expedition rides hauling a heavily laden trailer in the Oz bush. It runs much more sweetly than mine. He reckons it has saved him a black fortune in derailleurs in that time.
They are very much the tool and the only sensible choice for the serious mileage cyclist IMO.
Alfine 8: Got 3 in the family.
Can't fault the one I have on my Ti bike. Runs sweetly, and a nice gear change even though it's several years old. I also have one on a fat bike and it also is nice.
However the one on my daughter's bike feels like a fluid flywheel filled with treacle until it engages. It has done barely 100 miles though.
Sturmey-Archer 3 speed: have a few.
It's a shame they don't make a mtb version. This is the king of hubgears IMO. Light, you don't notice it on e back of the bike, clean straight chainline, and inexpensive. Will run forever with simple maintenance - I think nothing of taking my 70 year old bike out for 100 mile ride including rough stuff because I know the hub is reliable.
OK it's only 3 speeds, but it's light and simple - middle gear (direct) for the flats, low gear for the climbs and headwinds, and high gear for the downs and tailwinds. Our fathers and grandfathers rode the same roads (before they were sanitised and flattened) as we do with 3spds.
Posted : 15/10/2019 12:06 am
Extra (unsprung) weight Of an ihg would be likely to make (impact) punctures more common I’d say.
Ah, I see. And now you've put that in my head, I'll be thinking about it all the time and I can think of a few occasions when I have lost all the air from my back tyre after what felt like relatively ordinary impacts. 🙁
I don't really do the mega miles that is the Rohloff's trumpeted use case, either ... so this thread may end up costing me. Thanks, Singletrack…
Posted : 15/10/2019 9:40 am
I'd say that a lot of it is down to the bike it's fitted to too.
It probably makes less on a relatively burly steel hardtail with chunky 160 forks on the front.
I can't say that I've noticed more rear punctures than before (it was set up as a SS previously).
Yes you can just about feel that the weight is maybe more rear biased, but you just distribute you weight slightly differently.
Going by manufacturers quoted weights the difference between a 1x setup and an Alfine setup is only a matter of a few hundred grams.
Posted : 15/10/2019 1:36 pm
 Sven
Rohloff on my main MTB since 2006, maybe around 10 oil changes (if not fewer) in that time, and once I sent the wheel back to Rohloff, not that anything was wrong with it, I just felt someone taking it apart after 10 year for servicing might be a good idea; no charge apart from postage!
It's on an aluminium hardtail, my SS is lighter, my FS much heavier, so I like how light the bike feels. A derailleur bike might be 500g max lighter, but more punctures, really? Strangely enough this argument never comes up when people go on about the virtues of 1x drivetrains even though many cassettes have their own gravitational field, right at the same point where the Rohloff sits on mine (ignoring tubeless for a second, which eliminates snakebites anyway).
Positives: I spend less time servicing/repairing/replacing things and more time riding, looks 'clean', can shift while stationary or hopping before an obstacle, nice and quiet/no chain slapping, far less sensitive to the cable tension not being 100%; makes me more likely to go riding when muddy...
Negatives: read-wheel removal takes 10sec longer (track ends in my case with MonkeyBone), TwistShifter (I don't mind it too much, BUT: has anyone experimented with dropper post levers left and right, is the cable pull similar to Rohloff or the Cinq5 shifters?), I am not limited to frames with 135mm rear spacing.
For the future: Conversion kit to 142 or 148mm frames, and e-shifting kit by Rohloff for non-e-bikes, that would be neat.
Posted : 15/10/2019 2:26 pm
Yes you can just about feel most definantly feel that the weight is maybe more
rear biased
The burly 160ht would probably mask it more that's why mines now on a 4 inch tires 9zero7 can't feel the weight imbalance because the fronts heavy too.
Posted : 15/10/2019 2:32 pm
I've come back to this thread to say that I've just been out to my bike and there's no way I'd want to take the Rohloff off. I've had 3 years, including winters, of consistent, reliable and maintenance-free shifting.
I'd be happy to have 1x on another type of bike, but for this one, it's a big part of the bike's character. I think I am hooked.
As folk have said above, the weight of a cassette is not insignificant. And that's measured 'dry' – ie, before it's all clagged up with mud and grot. How many of us remove our cassettes to clean out all the mud that gets caught in the dish after every ride?
Honestly now...
Posted : 15/10/2019 3:39 pm
I've got a Rohloff on the all year round off road commuter. If you want gears then there is no better option for a bike that can be plastered in wet mud twice a day for a good proportion of the year. Mine has averaged a new chain and sprocket every 3 years and a new chainring every 6. Chain gets an occasional wipe and a liberal application of any old oil lying around and an annual oil change. Original shifter cables were still working when I changed them after 7 or 8 years despite the outer being quite badly cracked.
There are better options for bikes you ride when you want to ride but nothing better for bikes you ride when you need to ride.
Posted : 15/10/2019 4:18 pm
rear biased
Thanks for editing what I said, cos other people's opinions aren't at all valid are they? 🙄
In my personal experience I don't find the rear weight bias an issue at all, yes I notice it a bit, but I don't find it a massive problem.
However, putting that to one side, I'm in total agreement with Dorset_Knob. Low maintenance and consistent shifting in shitty weather on a bike trumps a bit of extra weight any day.
Posted : 15/10/2019 4:20 pm
I run an Alfine 11 on my Krampus and my mate runs a Rohloff on a BFe.
I don't feel the need to go back to derailleurs on the Krampus.
I do run derailleurs on my road & pub bikes and they do feel different.
I've worked out that any perceived additional drag in the Alfine can easily be overcome by getting fitter 😉
Posted : 15/10/2019 4:32 pm
 Del
You can put that to one side, I did that with an alfine. Kept smacking it in to shit. Did make my bunny hoping skills improve. When I occasionally think about building a geared hardtail I have no inclination to pick that alfine up off the bench.
Posted : 15/10/2019 5:52 pm
Issue is facts trump perceived opinion.
Facts are derailleur =95% -97% efficient. Rohloff 94% and Alfine 8 -90%. Nuvinci 83.5% efficient.
It weighs more than a quality drive train and that weight is concentrated out the back.
The good news is that if you output low power and you + bike weigh lots then those losses are all much less magnified than if you do as I did and put it on a racing snakes ultra light long distance race bike. I basically built a bike that exasperated all the issues and made them highly visible by putting them in a measurable environment......
Posted : 15/10/2019 6:03 pm
I'll take a rohloff over any other gear system any time.
Rode 2 alfine 8 into the ground.
Posted : 15/10/2019 6:12 pm
I fancy one.
Posted : 15/10/2019 6:18 pm
Rohloff.
Draggy, rear puncture prone and bearings kept getting play in them.
Alfine.
Even draggyer and hated the slow engagement.
Felt like it'd half engage then go kind of soft as you put the power down.
I love the idea of IGH's but couldn't put up with the downsides.
Love to try a Pinion but suspect it'd feel like a Rohloff.
Posted : 15/10/2019 6:52 pm
Yep, had an alfine based mtb in my quiver for years. Always have a winter mtb with one. My ebike has one too. Brilliant things, but do need to be maintained. Biggest issues are with dirty cables.
Posted : 15/10/2019 7:04 pm
I ran an alfine on my scandal for a few years. It did a couple of the original Kielder 100s including getting completely submerged in the head tube deep puddle of death. I liked being able to change gear without needing to pedal.
Then it failed catastrophically on the first pedal stroke of a family holiday doing the Coast and Castles and I ended up doing the whole ride singlespeed, towing a trailer, with my old alfine wheel lashed on top.
I realised they're great until they fail then there's more likelihood of getting a conventional derailleur fixed.
Posted : 16/10/2019 8:45 am
Just for clarity, my comments about the increased possibility of punctures in an igh equipped bike would only relate to the rear wheel.
And, ‘if’ a 1x setup weighed the same, then, if fitted to the same bike, would have the same effect.
However, that is only theory, i doubt anyone has done an actual study to prove/disprove it.
For the record, my mate owns the lbs, and has several customers come in with rohloff equipped bikes, the most that ever gets done to them is new sprocket, or oil change, or gear cable/adjustment..
I’d have one on an mtb, or a tourer, but probably not a racing bike.
I’ve used a bike with alfine 11 on it, id have a di2 one of those too.
Posted : 16/10/2019 11:31 am
Been using Alfines for MTB'ing for several years, here's my tales of , mainly, woe... But I do still like them when they are working.
Bought my first A11 from ad's on here, lasted area months before slipping gears could not be sorted by any amount of cable twiddling - they are very sensitive to adjustment & the "yellow lines" alignment is not the definitive setting. The original owner kindly got the hub replaced.
This then lasted about 2 years of regular use including my mainly off-road 10mile each way commute.
It failed with the shoulder supporting the main sun gear being the culprit. This shoulder does not fully support the side thrust on the gear due to the selector needing to pass through to the pawls.
Bought a new axle assembly (£55), rebuilt it & went again for another year until the disc mount sheared off the hub body - seems to be a common failure mode as the material at the junction is somewhat lacking... Also hub bodies are not available as spares.
Bought a new S7000-8, the 8 speed with the correct way shifting, also has more meat around the disc mount, ran fine for 2 1/2 years until earlier this week when the thing failed with the sun gear shoulder issue. No spares are available.
Am now building the old 11 speed internals into another hub body, that has apparently dead internals, bequeved from a kind fellow on here last year.
When that one fails, it will be a toss up between sun gear shoulder or disc mount - have machined a fillet radius into the junction on the replacement hub as there's a horrible sharp transition there - to see if that helps.
So, unless you have a lot of patience, ability to take these things apart & use with a lot of mechanical sympathy, I'd steer clear of an Alfine & stick with a derrailier set up. As said earlier, I do still like the things when they are working, simple & cheap drivetrain maintenance, smooth & quiet but they are more draggy than a derrailier set up.
Posted : 16/10/2019 11:33 am
I don't currently use an internal hub, but ran an Alfine for a couple of years a few years ago. Mechanically it was excellent, and made perfect sense. The gears ran smoothly, maintenance was minimal, etc. The gripshift wasn't ideal, and changing gear took a bit more thought, but having the gears on the inside is the only logical way.
But the weight balance was a real issue, and made the bike feel lifeless on the trails. I swapped it out for a conventional XT mech setup and spent some time setting up the cables properly, and haven't looked back
Posted : 16/10/2019 2:32 pm
I haven't used a hub gear in years, but as the other contributors have suggested, hub gears seem to make more sense on e-bikes.
I am intrigued by the newer sturmey-archer three speeds as they have got rid of the 'deadly' gear slippage of yore.
Apparently, they're still not designed for mud.
Some bloke on the forum successfully adapted his 3-speed to sealed bearings. Maybe they should do this at the factory.
Posted : 16/10/2019 11:32 pm
What really does surprise me is that no-one has yet put out an e-bike drive with integrated gearbox.
https://www.intra-drive.com/
Posted : 17/10/2019 12:28 am
One think to bear in mind about hub gears, especially Rohloff and S-A, is if they are properly maintained, then they are not consumables like derailleur setups and will outlast several sets of them.
Posted : 17/10/2019 1:26 pm
Great point. My Alfine 8 was secondhand 5/6 years ago. Cost me £100ish. In that time I've bought some ATF fluid for it, a couple of sprockets and maybe 2 chains. So very low running costs.
If looked after I'd hope to get another 5+ years out of it at least. But if it did go pop tomorrow it's cost me about £30 per year of use.
Posted : 17/10/2019 4:45 pm
Do the people who’ve had trouble with bearings on Rohloff do a lot of river crossings? I rode thousands of miles on Rohloff both off road and on in all weathers and never had an issue with bearings on any of our hubs.
Posted : 21/10/2019 2:57 pm
His photo has a real “went for a few beers after work on a Friday and got carried away, fell out of the club at 2am” vibe to it. Who wears a tie but doesn’t do up their top button?
Posted : 21/10/2019 3:01 pm
Not had any problems with the bearings on my Rohloff. It's still on the original bearings and seals after about 10000 miles of all weather MTBing, rarely being cleaned and it's still running fine. I only change the oil when I remember which is about every 18 months.
Regarding the weight issue I have never found it a problem; I haven't had a rear puncture in about 4 years either. The hub weighs about the same as the fork (RS Reba) so the bike balances right in the middle which I find quite nice.
Posted : 21/10/2019 5:38 pm
Page 2 / 2
