How easy is it to r...
[Closed] How easy is it to reconnect/ bleed a reverb?
[#7257859]
My gf has a bike with annoying routing for the dropper. It isn't stealth compatible but the cable has to go through the frame at one point. So
Posted : 10/08/2015 9:53 pm
Should be remote bleed only which is pretty easy.
Posted : 10/08/2015 9:56 pm
 jimw
Quite straightforward with the correct bleed kit. Much easier than bleeding Avid brakes!
Check out Epic bleed kits... they do one for the Reverb
Posted : 10/08/2015 9:58 pm
I had to remove the lever when installing my reverb. As long as you don't push the button in whilst its removed you shouldn't need to bleed it.
Posted : 10/08/2015 10:00 pm
