I wear Shimano M122 SPD's and my feet are getting soooooo cold it's not funny! Well My Toes to be precise.I've tried wearing 2 pairs of socks, even putting little plastic bags ( sad i know ) between socks, and my little digits are still going numb after an hour or so.
what do the wise on here do?
You've possibly got them done up too tight, or stuffed them with so many socks it's had the same effect. Looser shoes do help the warm blood flow better!
[url= http://cgi.ebay.co.uk/mens-HEAT-HOLDERS-THERMAL-SOCKS-2-3-TOG-6-11-ULTIMATE_W0QQitemZ310185867008QQcmdZViewItemQQptZMen_s_Clothes?var=&hash=item8e06dfa4ba ]i use heat holders, nice and toasty[/url]
I found wearing one pair of socks and letting your feet have a little room to move to get the air around them helps me out.
Assuming that you fit Shimano shoes then have a look at this thread - http://www.singletrackworld.com/forum/topic/psa-shimano-mw80-shoes
Merino inner sock, then a ground effect "toasty" outer sock, Spesh Defrosters in a one size bigger than I'd normally have so lots of room in toe box. Works a treat.
Have you always suffered from cold feet?
If so - you may not find a solution
There's a few threads on here with loads of suggestions for guaranteed toastie toes - but there's a few of us here where nothing works & you just learn to live with it [I've got cold feet sat here at my desk]
I spent many years & many £00's trying to solve it - to no avail
I've got boots that fit from Lake, Shimano & Gearne - I've also got a similar number of boots that are 1 & 2 sizes bigger & worn them with thick socks, thin socks, Sealskins etc.
I've worn them tight, slack & everywhere in-between - tried all the stuff for keeping legs & core warm
Nothing works - it's a circulation thing
I'm not saying it won't work for you but be prepared to be disappointed
I feel the cold badly.
I use these http://www.injinji.com/tetratsok/p_mini.htm dont laugh because they are utterly fantastic
What about those heat warmer pads that golfer's wear?
Bit like bad back heat pads, you pull them off the sticky which activatres them and they stay warm for 4 hours. They come in the shape of a top half of a foot
Is it just your toes? Could be a circulation issue when you're pressing on the SPDS's
For me, Northwave Celcius boots and two pairs of thin socks work great.
Flat pedals (your feet move more than in rigid boots), warm shoes (for obvious reasons), merino socks (cos sealskins are shite) and some overshoes (these are the clincher).
I used to suffer fom chronic cold feet... the overshoes over anytype of footwear solved it.
I use Nookie "titanium" neoprene socks and they are great.
What are you wearing on your legs? Try and keep your ankles and legs warm so the blood isn't being cooled by the time it reaches your feet.
Try putting a buff under your helmet.
My body, arm's & legs are like toast, no problemo.Just the feet.Never suffered from cold feet before I used SPD's.
I think maybe I just need to suck it up for the next month or two.Perhaps move the cleat on the shoe as far back as possible so there's more toe movement too.
Try pre heating your shoes on the radiator for an hour before you put them on. Overtightening the laces / straps also cause problems.
Overshoes. Don't inhibit circulation as they're an extra layer on the outside.
[url= http://www.amazon.co.uk/Health-Beauty-Cura-heat/s?ie=UTF8&rh=n%3A65801031%2Cp_4%3ACura-heat&page=1 ]Cura heat heat patches[/url]
Don't ride in SPDs in cold weather? Maybe it's just me, but I find having a nice cold cleat on the bottom of the shoe means my feet get much colder. 5 10's and merino socks seemed to be the right answer for me this morning...
Medium thickness socks, a shoe thats looser fitting and then overshoes...nice and toastie...or stay at home in front of a warm open fire 🙄
+1
I have always had this problem untill I bought a pair of Endura MT500 overshoes. They are brilliant, I was out in -5 degrees last week and my feet were toasty. They keep your feet dry aswell.
That combo has kept me warm even at -6...
Over shoesa re the answer, I got some last week after initially getting wet feet on a roadie ride, and then proper cold tootsies on my commute.
Got some [url= http://davehinde.veriovps.co.uk/Merchant2/merchant.mvc?Screen=PROD&Store_Code=DH&Product_Code=2xaztecpads&Category_Code=wheelpackages&Session_ID=8be8880ee1a6a6f8fca3c485d5bd33ee ]£15
BBB Heavy Duty ones[/url] and they're great, fit over normal MTB style shoes with ease.
Or you could get the roadie answer - turbo trainer for the next 3 months 😆
Using flats will help as you have two very good metal cold conductors attached to your feet (SPD pedals and cleats) and this is where the cold eventually finds its way in even you are using winter boots and overshoes as I do when the weather dips way below freezing.
I stopped wearing my summer riding shoes as they've got mesh fronts for increased windchill, and now wear Vans on flats and am toasty.
Socks are Sealskinz over twin skin running socks.
same as hands, helps if you can also keep you legs/arms warm as if they are cold they cool the blood going to the feet/hands.
i test some new stuff out last night in the snow.
on bottom half, gore winter bib tights, 3/4 baggies over the top.
brigdale super thick over knee hiking socks under tights, summer shimano shoes and them endura neoprene overshoes mt500..
feet were sweating!
