Screwdriver and hammer, but I imagine someone will be along to tell you to use the correct tools. ๐
You need the right freewheel removal tool
something like this:
[url= http://www.cyclingcloseouts.com/Departments/Tool-and-Repair/Component-Specific-Tool/Freewheel-Tools.aspx?&mode=all&sortOrder=4 ]freewheel tools[/url]
Local BMX shop should have one
You need a beer first
Hammer and wide scredriver will probably work, but then if you manage to fix the play it probably won't be worth putting back on. Get the right 4 prong tool. I like having the correct tool for the job, but then I'm a bit of a tool geek. Some may say there was no need for me to add geek there, but hey, whaddoIknow.
You need a freewheel removal tool and you'll have to put some weight behind it to get it undone*.
*Best to ask a grownup to help with this bit.
As above, it'll probably be very tight. I find its best to put the (correct) tool in a vice and turn the wheel. If you are friendly with your LBS it might be best just to get them to undo it.
a rock and an octopus...............i'll get my coat
I had the exact same issue a few months back (on my SS Genesis IO). Ended up buying a freewheel removal tool. The tool then was put in a vice and then the tyre was turned on top of the clamped tool.
Edit - beaten to it above!
uplink - Member
๐
Good luck and take a good look at your knuckles before hand they may never be the same again!
soma_rich - Member
but not to worry beer would ease the pain....
with these tools helps if you have a vice - but tool in vice face up, put wheel on top then undo wheel wheel rim + tyre as leverage..
as bods have mentioned above
saves knuckles and often easier to undo
Cheers all.
