How close can a gra...
[Closed] How close can a granny ring acceptably be to the chainstay?
 Aus
Building up a hardtail frame (Dekerf) with a Middleburn RS7 chainset (3 ring). I'm using the recommended 68 x 113mm b/b for chainline fit but, the granny ring is very very close to the chainstay (c.3mm). If I try an old XT chainset, the granyy ring is further from chainstay (5-6mm) which is more confidence inspiring!
I'd rather use the Middleburn, so what's an acceptable closeness of granny ring to chainstay?
Or do I need to have a wider axle - and will this put the chainline horribly out?
Posted : 20/06/2009 3:49 pm
As long as the chainline is ok, any clearance is enough (though keeping things in good condition to avoid chain suck would be wise).
Still, I recall going up a couple of mm of BB when switching from XT to RS7; reason was the front DR couldn't swing in far enough to get a good downchange to granny.
Posted : 20/06/2009 8:24 pm
2mm would be the limit for me. 3mm sounds fine. Either way, just go for a short spin and see if it leaves any marks.
Posted : 20/06/2009 8:55 pm
Te clearance is probably enough, you may struggle with the mech though
Posted : 20/06/2009 9:06 pm
