Hopr Pro2 freehub
[Closed] Hopr Pro2 freehub
[#7340455]
In the process of changing chain and cassette my cassette has become welded to my freehub body (alloy). I've tried to remove it but following some over enthusiastic banging with a mallet ive bent the lockring thread beyond repair. So, im after a new freehub body.
Steel is heavier, £2 cheaper and im guessing more resilient, is this ok paired with an XT cassette?
Posted : 19/09/2015 8:56 pm
 core
I'm running xt cassette on steel freehub, when I had my wheels through lbs they advised steel better for mashers/heavy lads. Hope recommend min. XT cassette on all their freehubs anyway don't they?
Posted : 19/09/2015 9:07 pm
hmm, im not sure. I had an SLX on their previously and when I took it off the freehub body looked a bit worse for wear. I filed off the bad bits and just stuck another SLX on. This time though it just wouldnt come off. I have a spare set of wheels on another bike, but that one is stuck on too!!
No ride tomorrow.
Posted : 19/09/2015 9:27 pm
Steel is good. I use one on a converted singlespeed wheel as the aluminium ones don't last long unless you buy premium sprockets.
FWIW if you do get a cassette stuck the easiest way I have found is to move it one sprocket at a time you can normally twist them back with a chain whip and wiggle them off. Takes a while but better than brute force. Or prise them off using a flat head screwdriver although I've normally managed to take the whole freehub body off doing that before.
Posted : 19/09/2015 9:31 pm
The problem with that is only the last 2 or 3 sprockets are removable individually on SLX I think. On XT/XTR its different.
Posted : 19/09/2015 9:34 pm
For tomorrow, you could just remove the freehub with the cassette attached, assuming they're both Pro2? I do it all the time, being a lazy get.....
Screwdriver or similar fed through spokes to the back of the cassette and tapped/hit/wellied with a hammer works.
Posted : 19/09/2015 9:36 pm
My method is to take the top two rings off, screw the lock ring back on, support the other side with two bits of wood and thump the lock ring with a rubber mallet.
Posted : 19/09/2015 9:42 pm
