Well ive finally given into the lure of Hydraulics and im eyeing up the spanking new Hope X2s only problem is budget is tight so im looking for them cheap. So does anyone know where i can get them from for around £200 for the full set? The best ive managed so far has been £230 from bike outlet (Thats 160 each end with IS mounts black hoses and standard rotors).
UKbikestore are fairly cheap normally
Lbs quoted £150 either end.
Told me they would also apply discount and fit.
UkBikestore are £131 an end Still not cheap enough but thanks mark.
Polaris both mine have quoted me silly prices without fitting but theyre both expensive anyway.
LBS did mine for £236 fitted. Thats including 10% loyalty bonus and £34 off as i didn't need rotors .Don't forget like i did .Hoses will almost certainly need shortening .Not that much of a faff but i was glad they did it .
Well ive no issues with fitting, im a trained bike mechanic lol But thank you for your contribution oldfart.
I seriously doubt you'll get them for your budget, there ain't a lot of mark up on them and their RRP is £160 per end.
Optimistic i know Blazin i thought i would give it a go on here just incase i was missing someone before i went with the place i found.
Ive just saw a set go on e-bay for £63 each no rotors or adapters mind but they're cheap enough anyway
Buy something else?
