Hope T-rex / Sunrac...
[Closed] Hope T-rex / Sunrace cassettes
Cassette is skipping; need a new one. The T-rex will be OK, gets used very rarely so won't be worn like the cassette is. However, I recall the T-rex is specific to either Shimano or Sram, and I can't remember what version I've got or hence what cassette.
Is there a way to tell without dismantling the cassette and taking off? I know that's lazy but if I take it apart I'll have to clean it all down, and it's not skipping badly enough in all gears yet that i can't leave it on until I get a new one delivered (next weekend) so I can ride tomorrow and Monday.
Or should I just get a Sunrace and be done - what's a second hand T-rex 40T worth?
Posted : 29/04/2017 2:58 pm
 Leku
I'm confused. Shirley you just look at what rear mech you have and that'll tell you?
Posted : 29/04/2017 3:29 pm
Mech won't tell me anything, you can use shimano on sram cassettes and vice versa.
Posted : 29/04/2017 3:32 pm
I love my sunrace on my titus
Posted : 29/04/2017 3:33 pm
 Leku
sorry Ill go back to drinking beer.
I had a T-Rex and my son has a Sunrace cassette. Both work well. Sunrise was easier to set up (no messing with a 16T sprocket).
Posted : 29/04/2017 3:35 pm
Are you saying that your current setup is so dirty that you can't tell if it's currently a sram or shimano cassette with a strip and clean? If so, I think I might know why it's not shifting well
Posted : 29/04/2017 3:36 pm
 tish
I'm sure mine had "shimano only" printed on it
Posted : 29/04/2017 3:39 pm
No, it's perfectly functionally clean, but I'm a bit OCD and if I take it off to look at it I'll end up with it in a bucket and lose an hour I really can't be arsed to spend now.
So, is there anyway to tell.
Oh and read the OP. It shifts fine, it skips (because I have a new chain on which I thought I'd get away with but clearly I'm not)
Posted : 29/04/2017 3:58 pm
And meanwhile you have waited an hour for a solution/answer on here .
Posted : 29/04/2017 4:01 pm
I'm not meaning to take this piss (just gently rib you perhaps). What cassette is in right now? Wouldn't that tell you which t-rex you've matched it to?
I haven't been sat here waiting, I'm watching football as well.
Onza; yes, that would be true but I can't find any identifying mark on the cassette either. It'll probably be printed on the back, meaning if I take it apart I can find out....... and then, etc.
Posted : 29/04/2017 4:07 pm
And you could have watched football with the cassette in a bucket.
Posted : 29/04/2017 4:09 pm
The lock ring would be a good place to look.
Posted : 29/04/2017 4:11 pm
should I have taken the bucket and the cassette to the game with me??
It's not the obvious accompaniment.
Amazing things these mobile devices.....
๐Ÿ˜ณ found out.
The lockring is a tarty after market colour matched one
Posted : 29/04/2017 4:12 pm
So, we're all invested now, you have to tell us, which is it?
Posted : 29/04/2017 4:13 pm
So its sitting on a bike at home and you still dont have your answer.
It could have been sitting in a bucket at home and you would have your answer when you got back.
[s]Numpty.[/s] sorry that was out of order. But someones grumpy. Sunderland fan perhaps.
Posted : 29/04/2017 4:15 pm
I'll take it apart when I get home...... sighs.
Hoped to be able to order a new cassette on line rather than watch the half time entertainment, instead ebds up being roundly abused ๐Ÿ˜‰
Posted : 29/04/2017 4:16 pm
Nice nairnster.
One day maybe you'll ask a simple question hoping for an answer. I hope someone helps you out.
Posted : 29/04/2017 4:19 pm
I would have just checked the cassette tbh.
And you were being one.
Posted : 29/04/2017 4:21 pm
I'd just order the sun race now. Mine shifts much better than my old expander setup. I also have an 11spd XT mech instead of a 10spd as it's designed for wide range cassettes and has the same pull ratio.
Posted : 29/04/2017 4:31 pm
nothing as glamorous as that, just local league stuff.
Not sure what sort of a one I was being, asked a simple question, which turns out even simpler now I know the answer, and got a mix of unhelpful advice and abuse (which I see you have now retracted). Sorry if you think that makes me a prick.
The answer is ....... Sram
There's nothing (visible) on the cassette to ID it that I can find, however on the T-Rex, etched into the cog, under only one of the (four) logos there is a tiny SR. Which I'm guessing means Sram, and Shimano will have a S or SH instead. And which I missed while looking quickly before heading out and isn't visible on the photo I took of it.
Posted : 29/04/2017 5:00 pm
Phew, another mystery solved.
Posted : 29/04/2017 5:02 pm
right, comparing the prices of Sram cassettes vs a new Sunrace, I'm going Sunrace.
Anyone want a T-Rex 40T extender for a Sram cassette - will throw in a worn 16t single cog to close the gap as well.
Posted : 29/04/2017 7:12 pm
I'm running both. On one bike I've got a Shimano 12-36 with a 40t Hope and a 16t cog to replace the 15t, on the other I've got a Sunrace 12-40. The Sunrace is cheaper and shifts as well, if not better than the buggered about with Shimano.
Posted : 29/04/2017 9:25 pm
