Hope Single Speed H...
[Closed] Hope Single Speed Hub Bearing Repalcement
 sp
[#3932831]
Need to service my Hope Single speed hub. Looking at the service diagram I can see three bearings one # 9 (61902) & two # 11 (61903)
([url= http://www.hopetech.com/page.aspx?itemid=SPG242&tab=technical ]Service Diagram[/url])
For some reason I thought there were five bearings???
Posted : 01/05/2012 5:09 pm
Well my Bulb has 4, so why should you have more!
I agree, it says 3 bearings
Posted : 01/05/2012 5:11 pm
Five in the standard Pro2, you have a needle roller replacing two 6802 bearings.
Posted : 01/05/2012 6:51 pm
 sp
Ah I see, should the needle roller bearing also be replaced? I have slight movement left/right
Posted : 01/05/2012 6:58 pm
Same bearings as standard ProII, so yes 5 in total just not as spread out...
Posted : 01/05/2012 7:47 pm
