Hope Pro 5 hubs - c...
Hope Pro 5 hubs - centrelock lockring options
I'm helping my friend put together a gravel bike and his wheels use Hope Pro 5 hubs, which I'm familiar with, but with centrelock brakes I'm not.
Hope sell lockrings with internal or external tightening options - apart from the different tools to tighten, is there any difference? Any advice based on experiences, etc?ย
(The discs are 160mm Shimano Ice Techs, XTR I think, if that makes a difference)
Posted : 26/09/2025 11:18 am
Need external for a 15mm front axle, rear can be either
Posted : 26/09/2025 11:28 am
Ah, perfect. Many thanks!
Posted : 26/09/2025 11:32 am
What STR said.
You do need to get them from the hub manufacturer as there are (at least) 2 different ways the external ones can have the 'external' lockrings. So if you're tempted away from Hope, check the thread specifications.
ย
ย
Posted : 26/09/2025 11:35 am
Yep, understood. The Hope hubs have the thread inside the hub.ย
ย
One thing I have just thought though, I'm pretty sure the hubs in question are actually 12mm front thru axle... would that sound right for the carbon forks you'd get with a Sonder Camino Ti?
Posted : 26/09/2025 11:48 am
Yes that's correct
Posted : 26/09/2025 12:29 pm
Thank you
Posted : 26/09/2025 1:33 pm
