Hope pro 4 freehub ...
Hope pro 4 freehub fitting question...
[#12493545]
Well sort of, we have a pro 4 freehub on a 142 width can I use it on a pro 4 148 hub? Just a case is swooping over the hubs and using wider end cap or not?
Posted : 05/08/2022 6:58 pm
Yes it's the end caps that change the width.
Posted : 05/08/2022 7:11 pm
I would try swapping over the freehub but keeping the endcap / hubs together.
Posted : 05/08/2022 7:38 pm
Should all be the same... Freehub and caps. Boost hubs are different to non boost
Posted : 05/08/2022 7:43 pm
Difference is in the hub body so endcap and freehubs are interchangeable. Only exception is if the 142 has been boosted. Note different end caps for different freehub designs.
Posted : 05/08/2022 9:03 pm
Yes it’s the end caps that change the width
This is wrong unless hub has been busy converted.
Posted : 05/08/2022 9:05 pm
