Hi all. Looking for some help with specs for this hub set for a re build into 650b. I have some conflicting spoke calculator info.
Hope has said 288mm (they should know I guess) but I am getting 291mm using my own measurements and don't want to cocktail it up. Erd is 584mm
Thanks
Do calculators work with straight pull? If it were me, and it was a rebuild, I'd compare erd of the two rims, then add that to the existing spokes.
if its a hub/rim combo that hope have sold in the past just call them and ask i did this with some pro2's and xc717's handed over the info no problem.
Thanks for the replies, i am building a 650b from what was a 26er so no direct comparisons. the DT swiss spoke calc does SP as do a couple of others.
I have realised that i had the offsets wrong which is why i had the discrepancies with the hope figure, all is now coming out at 288mm. so going to get ordering.
cheers
