Hi, I have a hope pro 2 rear hub, do you know if it is possible to put the pro 2 evo axle in to replace the original so that I can the just use the ends caps to swap between bikes instead or removing the axle everytime?
Thanks for the help!
You can convert an old Pro2 to an Evo, but you have to change everything apart from the hub shell.
Whys that then the bearing different sizes to fit the axle?
What ^ they said
I think justridingalong were doing a conversion kit at one point.
Eg replace the part no: hub217 for part hub229?
I had a ProII QR on a XM719 rim and a ProII EVO 12mm bolt thru on a XM317 rim and wanted the better rim on my full suss. Just stripped the two hubs and swapped the axles on rebuild. As long as you have the right tools I think you should be ok - worked for me anyway
