Hope Pro 2 Rear Axl...
[Closed] Hope Pro 2 Rear Axle - which one?
[#2330231]
I am 90% sure I need the 135mm QR version as I have QR on the hardtail. Though I am curious what is the difference between say the QR version and the 10mm through axle.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=18757 ]choice of axles[/url]
I had assumed there was one axel size and it was the end caps that made the axle compatible with different setups?
Posted : 02/01/2011 12:46 pm
Er, one is bored to take a QR skewer and the other a 10m through axle? Is this a trick question?
Posted : 02/01/2011 1:09 pm
You can use QR, 10mm bolt-in or 10mm bolt-through but the QR one is the standard. Bolt-in sounds like it is, and bolt-through you'd need a 10mm rear spindle.
(to explain why- your rear dropouts are 10mm, but you know how usually the wheel actually sits into the dropouts with 2 sticky out bits? So that even if the QR is out, the wheel still sits in the dropouts and doesn't fall through? Those are 10mm. The bolt-in and bolt-through doesn't have that, and uses that extra thickness for a fatter spindle.
Posted : 02/01/2011 1:32 pm
thats the deal for front hubs. rear hubs need different axles.
Posted : 02/01/2011 1:45 pm
Although the new Pro2 EVO is said to use just end caps to effect the change in axles.
Posted : 02/01/2011 3:31 pm
What is the difference between 12mm end caps, 10mm end caps and normal QR end caps?
Posted : 02/01/2011 8:15 pm
My 142mm x 12mm (X-12) rear conversion kit only has one end cap on the non drive side, the drive side is the axle.
Posted : 02/01/2011 8:26 pm
