hope mono minis - p...
[Closed] hope mono minis - piston stuck
[#2419888]
What with all the cold weather and salt on the road, my hope mini's piston has seized. How easy are they to replace? Rather hastily i have just ordered some new pistons from crc expecting the job to be striaght-forward! is it?
Posted : 30/01/2011 9:13 pm
Sticking pistons on Mono Minis is a common problem that can be sorted with Silicone grease, available of ebay from divers shops
Posted : 30/01/2011 9:39 pm
Seal kit would have been better option.
Posted : 30/01/2011 10:06 pm
Simple - is it mono minis? You really need the bore cap tool to replace seals and / or pistons
However there is a good chance that you don't even need to strip the caliper. Caliper off bike, pads out,hold in the moving piston and pump brake until stuck one starts to move - I find a cone spnner in the slot in the caliper works well to hold the piston. Clean around the piston once p[art way out, Brake fluid or rubber grease over the piston , work it in and out a few times.
Posted : 30/01/2011 10:17 pm
 Leku
[url= http://steveukmtb.wordpress.com/hope-caliper-overhaul-minitrialsm4v2m6/ ]How to here[/url]
I have just sent mine back to Hope for servicing. £40 which includes new pads.
Posted : 30/01/2011 10:42 pm
I'd second Leku. Unless you like faff send them back to Hope and they'll come back like new. Usually a super quick turnaround too.
Posted : 30/01/2011 11:42 pm
Same as tandemjeremy. I gently clamped the moving piston, then pumped the seized one out. Greased, then pushed back in. it took about 10 mins.
Posted : 31/01/2011 10:26 am
ive got to do this on my avids this week after advice on this forum last week. I wish I had the option of sending them back to hope!
Posted : 31/01/2011 12:35 pm
Yeah its not a hard job, just a bit of a faff. Just follow TJ advice and clean the stuck piston
I've got to do the exact same with one of my M4 Calipers
Posted : 31/01/2011 5:26 pm
I know it sounds kind of obvious, but don't just clean/lube the piston that is/was sticking. Putting something in the rotor slot, like a washer as shown in my overhaul guide that Leku linked, will allow you to fully extend both pistons.
Posted : 31/01/2011 5:44 pm
