Hope mono m4 disc r...
[Closed] Hope mono m4 disc rubbing
Got a set of Hope Mono M4 which are rubbing front and back-is it just a case of removing pads and lubing the pistons and pushing them back and recentering? Or is there something else I'm missing?
Posted : 05/08/2015 5:07 am
Consistently or intermittently?
Newly fitted or just started?
Push the pistons back, check the alignment (hope have a video on it)
Check the rotors are straight
Posted : 05/08/2015 5:09 am
It's consistent and been fitted for a long time but not sure how long they've been rubbing as it's a pals bike.
Posted : 05/08/2015 5:18 am
Pads out, old toothbrush and some silicon or brake fluid, give everything a good clean up and lube, push the Pistons back in...
Other option if they have been topped up recently is the resovoir may be over full....
Posted : 05/08/2015 6:08 am
Definitely not the latter Rick!
Posted : 05/08/2015 6:11 am
Loosen calliper bolts, pull and hold brake lever fully on, tighten calliper bolts.
Posted : 05/08/2015 6:20 am
spacemonkey - Member
Is not the way to set up hopes. Center the caliper properly.
Posted : 05/08/2015 6:22 am
