Hope Mini pistons s...
[Closed] Hope Mini pistons seized onto disc
Decided to spring clean one of my bikes this afternoon only to take it for a spin and have the front pistons clamp on after a few metres. I remember this happening last year but don't recall how I resolved it (temporarily it seems now).
All I did to the brakes beforehand was scuff up the pads and stick some cleaner on the discs.
Any ideas? Ta
Posted : 25/04/2013 1:43 pm
Sorted. Bit of cooling requiring and job done. Now have to figure out why it's been sticking.
Posted : 25/04/2013 1:57 pm
It's probably either knackered seals on the pistons, or an accumulation of brake dust or the phenolic pistons crumbling (a la Avid Juicys) but the latter is unlikely.
Posted : 25/04/2013 2:29 pm
Apparently some silicone lube on them (with no brake pads in) might help them become unstuck until you can do a proper job on them later?
-So a guy from Hope told me!
Posted : 25/04/2013 2:57 pm
Dot brake fluid absorbs moisture over time, when they warm the fluid expands and locks the brake on, that's probably why they were ok when they cooled down, a quick fix is to open the bleed nipple to let out the excess fluid but it'll need a bleed to sort it out properly
Posted : 25/04/2013 3:46 pm
Bu88er, was hoping a bleed wasn't necessary. Will check the seals etc.
Cheers chaps
Posted : 25/04/2013 4:24 pm
