Hope mini lever pul...
[Closed] Hope mini lever pulled out too far
Has anyone pulled their Hope mini lever out too far?
I haven't taken mine apart yet but any ideas on the broken part?
Did you fix it yourself?
Posted : 28/03/2011 9:50 pm
chances are you've popped one or both of the circlips that hold it all together..
expect to swear a lot as you put it back together.
Posted : 28/03/2011 10:00 pm
As above, possible circlip damage,and distortion to the brass retaining washer it holds in.9 times out of 10 the brass washer can be laid on a hard flat surface, and straightened with a well aimed hit from a hammer, this is a good thing as they're nearly £4 each.Be gentle/careful when dis-assembling and the piston will stay in it's bore, so you won't need to bleed it.
Posted : 29/03/2011 6:46 am
Just buy the rebuild kit and take it apart, you won't believe how easy it is, only problem is you will have to bleed it after, but that's not really a problem
Posted : 29/03/2011 8:04 am
