Hope matchmakers an...
[Closed] Hope matchmakers and avid brakes
Anyone running a Hope matchmaker with avid brakes / gears? Need to know if it is compatible - I guess it will depend on the bolt holes being in the right place for the brake?
Broken two avid matchmakers under pretty innocuous circumstances so want to try something different - it's an elixir brake and X9 shifter pod.
Posted : 10/12/2012 1:27 pm
The hole centres are near identical, and fitted fine on the set I tested, worst case scenario is they'll need a tickle with a file.
Posted : 10/12/2012 6:59 pm
I've got a pair of sliver. Matchmakers you can have forr £10 posted
Posted : 10/12/2012 7:06 pm
Yup, I've got a set of juicy 7 mated to hope xt matchmakers. The bolt centres are a gnats chuff wider on the matchmakers, but if you fit both bolts loose they'll do up fine.
Posted : 10/12/2012 7:09 pm
Thks all. I'll drop you a mail easygirl about the mm.
Posted : 10/12/2012 8:41 pm
